Up to 20% off select tools
Huawei Union Screen Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
70
All Time:
1,093
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide if your Huawei Union will not power on when the power button is pressed and you need to replace the screen.
    1. Huawei Union Screen Replacement, Battery: step 1, image 1 of 2 Huawei Union Screen Replacement, Battery: step 1, image 2 of 2
      • Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
      Ask FixBot
    2. Huawei Union Screen Replacement: step 2, image 1 of 2 Huawei Union Screen Replacement: step 2, image 2 of 2
      • Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
      Ask FixBot
    1. Huawei Union Screen Replacement, Camera Lens Panel: step 3, image 1 of 1
      • Remove the thirteen 3mm Phillips #00 screws from the back panel.
      Ask FixBot
    2. Huawei Union Screen Replacement: step 4, image 1 of 1
      • Use the flat end of a spudger to pry off the back panel.
      Ask FixBot
    1. Huawei Union Screen Replacement, Motherboard: step 5, image 1 of 1
      • Remove a single 3mm Phillips #00 screw from the motherboard.
      Ask FixBot
    2. Huawei Union Screen Replacement: step 6, image 1 of 2 Huawei Union Screen Replacement: step 6, image 2 of 2
      • Using the flat end of a spudger to disconnect the motherboard ribbon cable.
      Ask FixBot
    3. Huawei Union Screen Replacement: step 7, image 1 of 1
      • Firmly hold the second ribbon cable's plastic film cover and pull up to disconnect.
      Ask FixBot
    4. Huawei Union Screen Replacement: step 8, image 1 of 2 Huawei Union Screen Replacement: step 8, image 2 of 2
      • Wedge the flat end of a spudger underneath the motherboard and pry upwards to separate it from the frame.
      Ask FixBot
    1. Huawei Union Screen Replacement, Screen: step 9, image 1 of 1
      • Using an iOpener heat source tool, warm the screen of the phone to loosen adhesive of the screen.
      Ask FixBot
    2. Huawei Union Screen Replacement: step 10, image 1 of 2 Huawei Union Screen Replacement: step 10, image 2 of 2
      • Wedge an opening pick underneath the screen and slowly work your way around the screen.
      Ask FixBot
    3. Huawei Union Screen Replacement: step 11, image 1 of 2 Huawei Union Screen Replacement: step 11, image 2 of 2
      • Using multiple Opening Picks, work your way around the edges making sure not to place too much pressure at any one point.
      • With each pass, move the Opening Pick further to complete separation.
      Ask FixBot
    4. Huawei Union Screen Replacement: step 12, image 1 of 3 Huawei Union Screen Replacement: step 12, image 2 of 3 Huawei Union Screen Replacement: step 12, image 3 of 3
      • Once screen is sufficiently separated, holding the sides of the frame firmly, use the Spudger to press through the small access window to the screen at the top let and completely separate the screen from the frame.
      • Do not push too firmly. Screen may break. If screen will not separate, use iOpener heating element again and start over.
      • Do not press too far when separating the screen. There is a small ribbon cable attached to the screen that must be gently drawn through small access window.
      Ask FixBot
    5. Huawei Union Screen Replacement: step 13, image 1 of 1
      • Pull screen away from frame making sure the ribbon cable stays attached.
      Ask FixBot
Author
with
Brittany Achor
783 Reputation
6 Guides authored
USF Tampa, Team S1-G1, Nance Spring 2018 Member of USF Tampa, Team S1-G1, Nance Spring 2018
USFT-NANCE-S18S1G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 70
All Time: 1,093
