Up to 20% off select tools
Huawei Union Camera Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
12
Past 30 Days:
66
All Time:
705
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide if the Huawei Union’s camera will not work properly.
    1. Huawei Union Camera Replacement, Battery: step 1, image 1 of 2 Huawei Union Camera Replacement, Battery: step 1, image 2 of 2
      • Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
      Ask FixBot
    2. Huawei Union Camera Replacement: step 2, image 1 of 2 Huawei Union Camera Replacement: step 2, image 2 of 2
      • Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
      Ask FixBot
    1. Huawei Union Camera Replacement, Camera Lens Panel: step 3, image 1 of 1
      • Remove the thirteen 3mm Phillips #00 screws from the back panel.
      Ask FixBot
    2. Huawei Union Camera Replacement: step 4, image 1 of 1
      • Use the flat end of a spudger to pry off the back panel.
      Ask FixBot
    1. Huawei Union Camera Replacement, Camera: step 5, image 1 of 2 Huawei Union Camera Replacement, Camera: step 5, image 2 of 2
      • Use the flat end of a spudger to disconnect the camera from the motherboard.
      • Pull the camera out to remove.
      Ask FixBot
Author
with
Brittany Achor
783 Reputation
6 Guides authored
USF Tampa, Team S1-G1, Nance Spring 2018 Member of USF Tampa, Team S1-G1, Nance Spring 2018
USFT-NANCE-S18S1G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 66
All Time: 705
