Huawei SnapTo G-620 Microphone Replacement
    1. Huawei SnapTo G-620 Microphone Replacement, Battery: step 1, image 1 of 3 Huawei SnapTo G-620 Microphone Replacement, Battery: step 1, image 2 of 3 Huawei SnapTo G-620 Microphone Replacement, Battery: step 1, image 3 of 3
      • Pry open the back cover with your fingernail, using the divot to the lower left hand corner.
      • Remove all fifteen 4mm Phillips J00 screws on the back panel.
      • Using a metal spudger or your fingernail, remove the back panel.
      Ask FixBot
    2. Huawei SnapTo G-620 Microphone Replacement: step 2, image 1 of 1
      • Remove the pictured 4mm Phillips J00 screw.
      Ask FixBot
    3. Huawei SnapTo G-620 Microphone Replacement: step 3, image 1 of 2 Huawei SnapTo G-620 Microphone Replacement: step 3, image 2 of 2
      • Use a plastic opening tool to remove the pictured flat-top connector.
      Ask FixBot
    4. Huawei SnapTo G-620 Microphone Replacement: step 4, image 1 of 1
      • Remove the battery.
      Ask FixBot
    1. Huawei SnapTo G-620 Microphone Replacement, Microphone: step 5, image 1 of 2 Huawei SnapTo G-620 Microphone Replacement, Microphone: step 5, image 2 of 2
      • Using the plastic opening tool remove the camera.
      Ask FixBot
    2. Huawei SnapTo G-620 Microphone Replacement: step 6, image 1 of 3 Huawei SnapTo G-620 Microphone Replacement: step 6, image 2 of 3 Huawei SnapTo G-620 Microphone Replacement: step 6, image 3 of 3
      • Use the plastic opening tool to remove all the remaining flat-top connectors.
      Ask FixBot
    3. Huawei SnapTo G-620 Microphone Replacement: step 7, image 1 of 3 Huawei SnapTo G-620 Microphone Replacement: step 7, image 2 of 3 Huawei SnapTo G-620 Microphone Replacement: step 7, image 3 of 3
      • Using the spudger, pry open the zif connector, and remove the cable.
      Ask FixBot
    4. Huawei SnapTo G-620 Microphone Replacement: step 8, image 1 of 2 Huawei SnapTo G-620 Microphone Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers or the spudger, remove the microphone.
      Ask FixBot
Coleson Perry
101 Reputation
1 Guide authored
USF Tampa, Team S2-G6, Nance Fall 2017 Member of USF Tampa, Team S2-G6, Nance Fall 2017
USFT-NANCE-F17S2G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 21
Past 30 Days: 95
All Time: 567
