Up to 20% off select tools
Huawei SnapTo G-620 Camera Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
84
All Time:
746
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you are experiencing shutter delay with your Huawei SnapTo G-620's camera, then the camera may need to be replaced. This guide shows you how to replace your SnapTo's camera.
    1. Huawei SnapTo G-620 Camera Replacement, Camera: step 1, image 1 of 3 Huawei SnapTo G-620 Camera Replacement, Camera: step 1, image 2 of 3 Huawei SnapTo G-620 Camera Replacement, Camera: step 1, image 3 of 3
      • Pry open the back cover with your fingernail, using the divot to the lower left hand corner.
      • Remove all fifteen 4mm Phillips J00 screws on the back panel.
      • Using a metal spudger or your fingernail, remove the back panel.
      Ask FixBot
    2. Huawei SnapTo G-620 Camera Replacement: step 2, image 1 of 2 Huawei SnapTo G-620 Camera Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to remove the pictured flat-top connector.
      • Using the plastic opening tool remove the camera.
      Ask FixBot
Author
with
Brian Omer Uzan
401 Reputation
4 Guides authored
USF Tampa, Team S2-G6, Nance Fall 2017 Member of USF Tampa, Team S2-G6, Nance Fall 2017
USFT-NANCE-F17S2G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 84
All Time: 746
