Huawei SnapTo G-620 Battery Replacement
    1. Huawei SnapTo G-620 Battery Replacement, Battery: step 1, image 1 of 3 Huawei SnapTo G-620 Battery Replacement, Battery: step 1, image 2 of 3 Huawei SnapTo G-620 Battery Replacement, Battery: step 1, image 3 of 3
      • Pry open the back cover with your fingernail, using the divot to the lower left hand corner.
      • Remove all fifteen 4mm Phillips J00 screws on the back panel.
      • Using a metal spudger or your fingernail, remove the back panel.
      Ask FixBot
    2. Huawei SnapTo G-620 Battery Replacement: step 2, image 1 of 1
      • Remove the pictured 4mm Phillips J00 screw.
      Ask FixBot
    3. Huawei SnapTo G-620 Battery Replacement: step 3, image 1 of 2 Huawei SnapTo G-620 Battery Replacement: step 3, image 2 of 2
      • Use a plastic opening tool to remove the pictured flat-top connector.
      Ask FixBot
    4. Huawei SnapTo G-620 Battery Replacement: step 4, image 1 of 1
      • Remove the battery.
      Ask FixBot
Brian Omer Uzan
401 Reputation
4 Guides authored
USF Tampa, Team S2-G6, Nance Fall 2017 Member of USF Tampa, Team S2-G6, Nance Fall 2017
USFT-NANCE-F17S2G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 112
All Time: 1,103
