Huawei Pronto LTE Battery Replacement
    1. Huawei Pronto LTE Battery Replacement, Battery: step 1, image 1 of 2 Huawei Pronto LTE Battery Replacement, Battery: step 1, image 2 of 2
      • Remove the back cover of your Huawei Pronto LTE using an opening tool.
      • Lift the back cover off of the device after the four corners are unlatched.
      Ask FixBot
    2. Huawei Pronto LTE Battery Replacement: step 2, image 1 of 3 Huawei Pronto LTE Battery Replacement: step 2, image 2 of 3 Huawei Pronto LTE Battery Replacement: step 2, image 3 of 3
      • Remove the 15 screws on the back of the device using a Phillips #000 screwdriver.
      • Hold the device in place while you are doing this step.
      • Lift the inner cover gently by using a spudger.
      Ask FixBot
    3. Huawei Pronto LTE Battery Replacement: step 3, image 1 of 3 Huawei Pronto LTE Battery Replacement: step 3, image 2 of 3 Huawei Pronto LTE Battery Replacement: step 3, image 3 of 3
      • Detach the yellow latches along the sides to remove the motherboard.
      Ask FixBot
    4. Huawei Pronto LTE Battery Replacement: step 4, image 1 of 3 Huawei Pronto LTE Battery Replacement: step 4, image 2 of 3 Huawei Pronto LTE Battery Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Ensure that all latches are detached and that there are no extra screws to avoid damaging the motherboard.
      • Use tweezers to gently remove the motherboard from the device.
      Ask FixBot
    5. Huawei Pronto LTE Battery Replacement: step 5, image 1 of 3 Huawei Pronto LTE Battery Replacement: step 5, image 2 of 3 Huawei Pronto LTE Battery Replacement: step 5, image 3 of 3
      • The battery should be revealed once the motherboard is removed.
      • Lift the battery from the top left corner.
      Ask FixBot
Crystal Edwards
450 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 66
All Time: 1,388
