Huawei Phone p7 Power Flex Replacement
    1. Huawei Phone p7 Power Flex Replacement, Power Flex: step 1, image 1 of 3 Huawei Phone p7 Power Flex Replacement, Power Flex: step 1, image 2 of 3 Huawei Phone p7 Power Flex Replacement, Power Flex: step 1, image 3 of 3
      • Remove back cover.
      Ask FixBot
    2. Huawei Phone p7 Power Flex Replacement: step 2, image 1 of 2 Huawei Phone p7 Power Flex Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Use the tweezers or some tools thin and sharp to cut the adhesive between power flex and bracket. And then pry it up and remove it.
      Ask FixBot
5 other people completed this guide.
Sophia
43,911 Reputation
62 Guides authored
2 Guide Comments
When you say follow the steps in reverse to finish the repair, what exactly happens with the glue melted in the first step? Do you just reheat the back cover to set it again, or do you need to apply your own glue? Similarly for the power flex. You mention you need to pry past the glue, does this indicate it also needs to be glued back into place?
Willem-Frederick ter Haar - Reply Share
You have to add an adhesive on the edges of the back cover. Don't apply heat from the heat blower
clinton opara - Reply Share
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 99
All Time: 2,818
