Introduction
Go to step 1 ↓If your Huawei P9 Plus won't hold a charge you can use this guide to replace the worn-out battery.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Remove the sticker that sits on top of the left screw above the battery.
Remove the three Phillips #00 screws that hold the metal plates in place.
To reassemble your device, follow these instructions in reverse order and apply new adhesive strips where necessary.
12 other people completed this guide.
