Huawei P9 Lite Rear Camera Replacement
    1. Huawei P9 Lite Rear Camera Replacement, Back Cover: step 1, image 1 of 2 Huawei P9 Lite Rear Camera Replacement, Back Cover: step 1, image 2 of 2
      • Use an opening pick to unclip the rear cover, starting from the bottom corner.
      • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
      Ask FixBot
    2. Huawei P9 Lite Rear Camera Replacement: step 2, image 1 of 1
      • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
      • Be careful with the flex cable at the right hand side.
      • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
      Ask FixBot
    3. Huawei P9 Lite Rear Camera Replacement: step 3, image 1 of 1
      • When the back cover is freed from the adhesive you can pop it off by hand completely.
      Ask FixBot
    1. Huawei P9 Lite Rear Camera Replacement, Motherboard Shield: step 4, image 1 of 1
      • Remove the nine Phillips #00 screws that secure the metal shield plate.
      • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
      Ask FixBot
    2. Huawei P9 Lite Rear Camera Replacement: step 5, image 1 of 2 Huawei P9 Lite Rear Camera Replacement: step 5, image 2 of 2
      • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
      • Use a spudger to disconnect the fingerprint sensor from the motherboard.
      • Peel the NFC antenna cable off of the metal plate.
      Ask FixBot
    1. Huawei P9 Lite Rear Camera Replacement, Rear Camera: step 6, image 1 of 2 Huawei P9 Lite Rear Camera Replacement, Rear Camera: step 6, image 2 of 2
      • Release the rear camera connector.
      • Take the camera out of its recess.
      Ask FixBot
6 other people completed this guide.
Tobias Isakeit
135,840 Reputation
189 Guides authored
2 Guide Comments
So, i ordered some replacement parts for my huawei p9 lite(Main camera, front camera, usb board), Everything i replaced is working, except for the main camera, the new main camera isn’t working, because when i open my camera app it immediately closes, snapchat shows me an error that says: Snapchat was unable to open the camera app. I made sure that the new main camera isn’t working for some reason, because when i put my original camera back in, everything works, including the new front camera). Am i missing something, could it be a hardware problem or a software problem? Please help, i need advices quick. Thanks.
Zygis Bugenis - Reply Share
My mobile phon p9 lite camera removed without strip how to adjust camera in lens??
junaid ali jan - Reply Share
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 102
All Time: 4,219
