Huawei P9 Lite Motherboard Replacement
    1. Huawei P9 Lite Motherboard Replacement, Back Cover: step 1, image 1 of 2 Huawei P9 Lite Motherboard Replacement, Back Cover: step 1, image 2 of 2
      • Use an opening pick to unclip the rear cover, starting from the bottom corner.
      • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
      Ask FixBot
    2. Huawei P9 Lite Motherboard Replacement: step 2, image 1 of 1
      • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
      • Be careful with the flex cable at the right hand side.
      • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
      Ask FixBot
    3. Huawei P9 Lite Motherboard Replacement: step 3, image 1 of 1
      • When the back cover is freed from the adhesive you can pop it off by hand completely.
      Ask FixBot
    1. Huawei P9 Lite Motherboard Replacement, Motherboard Shield: step 4, image 1 of 1
      • Remove the nine Phillips #00 screws that secure the metal shield plate.
      • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
      Ask FixBot
    2. Huawei P9 Lite Motherboard Replacement: step 5, image 1 of 2 Huawei P9 Lite Motherboard Replacement: step 5, image 2 of 2
      • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
      • Use a spudger to disconnect the fingerprint sensor from the motherboard.
      • Peel the NFC antenna cable off of the metal plate.
      Ask FixBot
    1. Huawei P9 Lite Motherboard Replacement, Motherboard: step 6, image 1 of 2 Huawei P9 Lite Motherboard Replacement, Motherboard: step 6, image 2 of 2
      • Remove the SIM card tray.
      Ask FixBot
    2. Huawei P9 Lite Motherboard Replacement: step 7, image 1 of 3 Huawei P9 Lite Motherboard Replacement: step 7, image 2 of 3 Huawei P9 Lite Motherboard Replacement: step 7, image 3 of 3
      • Disconnect the motherboard flex, the battery flex and the antenna cable.
      Ask FixBot
    3. Huawei P9 Lite Motherboard Replacement: step 8, image 1 of 2 Huawei P9 Lite Motherboard Replacement: step 8, image 2 of 2
      • Disconnect the display flex and the power and volume button cable.
      Ask FixBot
    4. Huawei P9 Lite Motherboard Replacement: step 9, image 1 of 2 Huawei P9 Lite Motherboard Replacement: step 9, image 2 of 2
      • Unplug the rear camera and the headphone jack.
      Ask FixBot
    5. Huawei P9 Lite Motherboard Replacement: step 10, image 1 of 2 Huawei P9 Lite Motherboard Replacement: step 10, image 2 of 2
      • Take the camera and the headphone jack out of their recesses.
      Ask FixBot
    6. Huawei P9 Lite Motherboard Replacement: step 11, image 1 of 3 Huawei P9 Lite Motherboard Replacement: step 11, image 2 of 3 Huawei P9 Lite Motherboard Replacement: step 11, image 3 of 3
      • Use a spudger to lift the motherboard carefully.
      • Remove the motherboard assembly.
      • On the back of the motherboard there is a thermal pad (pink rubber-like gob) for heat dissipation. If you are about to replace the display assembly, and the thermal pad broke or is too dried out, you might want to replace it with a new one.
      Ask FixBot
9 other people completed this guide.
Tobias Isakeit
135,873 Reputation
189 Guides authored
1 Guide Comment
Aslam-0-alaikum
Sir p9lite ka motherboard mil jya ja to plz bta da kitny ka ha
Rajab Ali - Reply Share
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 138
All Time: 10,228
