Huawei P9 Lite Loudspeaker Replacement
    1. Huawei P9 Lite Loudspeaker Replacement, Back Cover: step 1, image 1 of 2 Huawei P9 Lite Loudspeaker Replacement, Back Cover: step 1, image 2 of 2
      • Use an opening pick to unclip the rear cover, starting from the bottom corner.
      • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
      Ask FixBot
    2. Huawei P9 Lite Loudspeaker Replacement: step 2, image 1 of 1
      • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
      • Be careful with the flex cable at the right hand side.
      • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
      Ask FixBot
    3. Huawei P9 Lite Loudspeaker Replacement: step 3, image 1 of 1
      • When the back cover is freed from the adhesive you can pop it off by hand completely.
      Ask FixBot
    1. Huawei P9 Lite Loudspeaker Replacement, Loudspeaker: step 4, image 1 of 3 Huawei P9 Lite Loudspeaker Replacement, Loudspeaker: step 4, image 2 of 3 Huawei P9 Lite Loudspeaker Replacement, Loudspeaker: step 4, image 3 of 3
      • On the bottom of the phone remove the following screws:
      • Three 2.9 mm Phillips #00 screws
      • Four 3.8 mm Phillips #00 screws
      • Now you can grab the loudspeaker unit and take it out.
      Ask FixBot
12 other people completed this guide.
Tobias Isakeit
135,855 Reputation
189 Guides authored
3 Guide Comments
Was replacing the charging system bt now people can not hear me unless I put on loud speaker
dtotisitswe - Reply Share
Same problem here. Any help?
fabio9999 - Reply Share
Sir hy how are you. Sir p9lite song speaker not working.
Sufyan Raja - Reply Share
Past 24 Hours: 3
Past 7 Days: 36
Past 30 Days: 128
All Time: 11,260
