Up to 20% off select tools
Huawei P9 Lite Front Camera Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
92
All Time:
4,679
Comments: 21
21 comments on steps.
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the front camera in your Huawei P9 Lite.
    1. Huawei P9 Lite Front Camera Replacement, Back Cover: step 1, image 1 of 2 Huawei P9 Lite Front Camera Replacement, Back Cover: step 1, image 2 of 2
      • Use an opening pick to unclip the rear cover, starting from the bottom corner.
      • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
      Ask FixBot
    2. Huawei P9 Lite Front Camera Replacement: step 2, image 1 of 1
      • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
      • Be careful with the flex cable at the right hand side.
      • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
      Ask FixBot
    3. Huawei P9 Lite Front Camera Replacement: step 3, image 1 of 1
      • When the back cover is freed from the adhesive you can pop it off by hand completely.
      Ask FixBot
    1. Huawei P9 Lite Front Camera Replacement, Motherboard Shield: step 4, image 1 of 1
      • Remove the nine Phillips #00 screws that secure the metal shield plate.
      • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
      Ask FixBot
    2. Huawei P9 Lite Front Camera Replacement: step 5, image 1 of 2 Huawei P9 Lite Front Camera Replacement: step 5, image 2 of 2
      • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
      • Use a spudger to disconnect the fingerprint sensor from the motherboard.
      • Peel the NFC antenna cable off of the metal plate.
      Ask FixBot
    1. Huawei P9 Lite Front Camera Replacement, Motherboard: step 6, image 1 of 2 Huawei P9 Lite Front Camera Replacement, Motherboard: step 6, image 2 of 2
      • Remove the SIM card tray.
      Ask FixBot
    2. Huawei P9 Lite Front Camera Replacement: step 7, image 1 of 3 Huawei P9 Lite Front Camera Replacement: step 7, image 2 of 3 Huawei P9 Lite Front Camera Replacement: step 7, image 3 of 3
      • Disconnect the motherboard flex, the battery flex and the antenna cable.
      Ask FixBot
    3. Huawei P9 Lite Front Camera Replacement: step 8, image 1 of 2 Huawei P9 Lite Front Camera Replacement: step 8, image 2 of 2
      • Disconnect the display flex and the power and volume button cable.
      Ask FixBot
    4. Huawei P9 Lite Front Camera Replacement: step 9, image 1 of 2 Huawei P9 Lite Front Camera Replacement: step 9, image 2 of 2
      • Unplug the rear camera and the headphone jack.
      Ask FixBot
    5. Huawei P9 Lite Front Camera Replacement: step 10, image 1 of 2 Huawei P9 Lite Front Camera Replacement: step 10, image 2 of 2
      • Take the camera and the headphone jack out of their recesses.
      Ask FixBot
    6. Huawei P9 Lite Front Camera Replacement: step 11, image 1 of 3 Huawei P9 Lite Front Camera Replacement: step 11, image 2 of 3 Huawei P9 Lite Front Camera Replacement: step 11, image 3 of 3
      • Use a spudger to lift the motherboard carefully.
      • Remove the motherboard assembly.
      • On the back of the motherboard there is a thermal pad (pink rubber-like gob) for heat dissipation. If you are about to replace the display assembly, and the thermal pad broke or is too dried out, you might want to replace it with a new one.
      Ask FixBot
    1. Huawei P9 Lite Front Camera Replacement, Front Camera: step 12, image 1 of 2 Huawei P9 Lite Front Camera Replacement, Front Camera: step 12, image 2 of 2
      • Disconnect the front camera flex from the motherboard.
      • Flip the motherboard over and thread the flex cable through the opening and take the camera away.
      Ask FixBot
5 other people completed this guide.
Tobias Isakeit
136,837 Reputation
189 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 92
All Time: 4,679
