Parts
Tools
Introduction
Go to step 1 ↓Use this guide to replace the display of your Huawei P9 Lite.
Use an opening pick to unclip the rear cover, starting from the bottom corner.
Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
On the bottom of the phone remove the following screws:
Three 2.9 mm Phillips #00 screws
Four 3.8 mm Phillips #00 screws
Now you can grab the loudspeaker unit and take it out.
Remove the nine Phillips #00 screws that secure the metal shield plate.
Tool used on this step:Tesa 61395 Tape$8.95
Slide the spudger under the battery at the place shown in the picture and pry it loose slowly.
When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
Take the flat end of a spudger to disconnect the display flex cable.
Flip the phone over and use an iOpener to soften the adhesive at the edge of the display.
With a suction handle you can lift the display a little bit to create a gap.
Insert just the tip of an opening pick in the gap and steadily slide it along the edge towards the top. You may need to go back and forth a few times.
Try to get around the corner and behind the top part of the display. Re-position the suction handle if needed.
Leave the opening pick behind the display to avoid the re-sealing of the adhesive.
26 other people completed this guide.
3 Guide Comments
About release battery ... fishing braided line works better :) battery taken without any destruction.
Grazie a questa guida ho potuto sostituire batteria e schermo da me. Grazie!
Non si può sostituire solo il vetro? X forza anche lcd?
