Up to 20% off select tools
Huawei P9 Lite Battery Replacement
Views: 138K
View statistics:
Past 24 Hours:
4
Past 7 Days:
35
Past 30 Days:
202
All Time:
138,403
Comments: 53
26 comments on steps, 27 guide comments.
Go to guide comments
Completed: 89
89 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 50 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the old battery in your Huawei P9 Lite.
    1. Huawei P9 Lite Battery Replacement, Back Cover: step 1, image 1 of 2 Huawei P9 Lite Battery Replacement, Back Cover: step 1, image 2 of 2
      • Use an opening pick to unclip the rear cover, starting from the bottom corner.
      • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
      Ask FixBot
    2. Huawei P9 Lite Battery Replacement: step 2, image 1 of 1
      • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
      • Be careful with the flex cable at the right hand side.
      • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
      Ask FixBot
    3. Huawei P9 Lite Battery Replacement: step 3, image 1 of 1
      • When the back cover is freed from the adhesive you can pop it off by hand completely.
      Ask FixBot
    1. Huawei P9 Lite Battery Replacement, Loudspeaker: step 4, image 1 of 3 Huawei P9 Lite Battery Replacement, Loudspeaker: step 4, image 2 of 3 Huawei P9 Lite Battery Replacement, Loudspeaker: step 4, image 3 of 3
      • On the bottom of the phone remove the following screws:
      • Three 2.9 mm Phillips #00 screws
      • Four 3.8 mm Phillips #00 screws
      • Now you can grab the loudspeaker unit and take it out.
      Ask FixBot
    1. Huawei P9 Lite Battery Replacement, Motherboard Shield: step 5, image 1 of 1
      • Remove the nine Phillips #00 screws that secure the metal shield plate.
      • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
      Ask FixBot
    2. Huawei P9 Lite Battery Replacement: step 6, image 1 of 2 Huawei P9 Lite Battery Replacement: step 6, image 2 of 2
      • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
      • Use a spudger to disconnect the fingerprint sensor from the motherboard.
      • Peel the NFC antenna cable off of the metal plate.
      Ask FixBot
    1. Huawei P9 Lite Battery Replacement, Battery: step 7, image 1 of 3 Huawei P9 Lite Battery Replacement, Battery: step 7, image 2 of 3 Huawei P9 Lite Battery Replacement, Battery: step 7, image 3 of 3
      • Disconnect the motherboard flex cable on both ends and take it away.
      Ask FixBot
    2. Huawei P9 Lite Battery Replacement: step 8, image 1 of 2 Huawei P9 Lite Battery Replacement: step 8, image 2 of 2
      • Peel off the NFC antenna from the battery.
      • Be careful not to rip or crease the antenna.
      • If you are just removing the battery to get to the display, you can leave the NFC on the battery.
      • Unplug the battery connector.
      Ask FixBot
    3. Huawei P9 Lite Battery Replacement: step 9, image 1 of 3 Huawei P9 Lite Battery Replacement: step 9, image 2 of 3 Huawei P9 Lite Battery Replacement: step 9, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • Slide the spudger under the battery at the place shown in the picture and pry it loose slowly.
      • Avoid bending the battery and reheat if necessary.
      • Be careful not to damage the display flex cable that runs underneath the battery in the center.
      • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
      Ask FixBot
89 other people completed this guide.
Author
with
Tobias Isakeit
136,837 Reputation
189 Guides authored
27 Guide Comments
There is an extra step where you need to remove the cover of the board at the top of the phone in order to remove the NFC antenna which is not described in this guide. Better watch this https://www.youtube.com/watch?v=ADZiL7JK...
Costas Geraniou - Reply Share
Thanks Costas for the hint. We added the missing step.
Tobias Isakeit - Reply Share
Very very thanks!
Artur - Reply Share
Cercando di rimouorere l'adesivo dell'nfc si è rotto, posso assembrale il telefono senza nfc, ovviamente invalidando questa funzione?
Francesco Staiano - Reply Share
Si, hai ragione: si può riassemblare il telefono senza l’antenna NFC perdendo questa funzione…
Claire Miesch - Reply Share
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 202
All Time: 138,403
