Up to 20% off select tools
Huawei P9 Lite Back Cover Replacement
Views: 26K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
108
All Time:
26,395
Comments: 12
12 comments on steps.
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the back cover of your Huawei P9 Lite.
    1. Huawei P9 Lite Back Cover Replacement, Back Cover: step 1, image 1 of 2 Huawei P9 Lite Back Cover Replacement, Back Cover: step 1, image 2 of 2
      • Use an opening pick to unclip the rear cover, starting from the bottom corner.
      • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
      Ask FixBot
    2. Huawei P9 Lite Back Cover Replacement: step 2, image 1 of 1
      • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
      • Be careful with the flex cable at the right hand side.
      • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
      Ask FixBot
    3. Huawei P9 Lite Back Cover Replacement: step 3, image 1 of 1
      • When the back cover is freed from the adhesive you can pop it off by hand completely.
      Ask FixBot
15 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,208 Reputation
682 Guides authored
iFixit EU Team Member of iFixit EU Team
Staff
36 Members
3,072 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 108
All Time: 26,395
