Huawei P9 Headphone Jack Replacement
    1. Huawei P9 Headphone Jack Replacement, Back Cover: step 1, image 1 of 3 Huawei P9 Headphone Jack Replacement, Back Cover: step 1, image 2 of 3 Huawei P9 Headphone Jack Replacement, Back Cover: step 1, image 3 of 3
      • First switch off your phone and remove the SIM card tray.
      • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
      • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
      Ask FixBot
    2. Huawei P9 Headphone Jack Replacement: step 2, image 1 of 2 Huawei P9 Headphone Jack Replacement: step 2, image 2 of 2
      • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
      • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
      • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
      • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
      Ask FixBot
    3. Huawei P9 Headphone Jack Replacement, Fingerprint sensor: step 3, image 1 of 2 Huawei P9 Headphone Jack Replacement, Fingerprint sensor: step 3, image 2 of 2
      • Disconnect the fingerprint sensor using a spudger.
      Ask FixBot
    1. Huawei P9 Headphone Jack Replacement, Headphone Jack: step 4, image 1 of 3 Huawei P9 Headphone Jack Replacement, Headphone Jack: step 4, image 2 of 3 Huawei P9 Headphone Jack Replacement, Headphone Jack: step 4, image 3 of 3
      • Remove the water indicator on top of the screw.
      • Undo the two Phillips #00 screws.
      • Remove metal bracket (mind the adhesive underneath).
      Ask FixBot
    2. Huawei P9 Headphone Jack Replacement: step 5, image 1 of 2 Huawei P9 Headphone Jack Replacement: step 5, image 2 of 2
      • Disconnect the flex cable and remove the headphone jack.
      • The old headphone jack is equipped with a rubber seal, which holds the jack down to the phone. Take it off and put it on the new headphone jack.
      Ask FixBot
3 other people completed this guide.
Tobias Isakeit
135,840 Reputation
189 Guides authored
1 Guide Comment
questo procedimento funziona anche con il modello p9 plus? grazie per l’attenzione
abcde181 - Reply Share
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 121
All Time: 7,047
