Up to 20% off select tools
Huawei P9 Front Facing Camera Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
111
All Time:
2,679
Comments: 24
24 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the front facing camera in your Huawei P9.
    1. Huawei P9 Front Facing Camera Replacement, Back Cover: step 1, image 1 of 3 Huawei P9 Front Facing Camera Replacement, Back Cover: step 1, image 2 of 3 Huawei P9 Front Facing Camera Replacement, Back Cover: step 1, image 3 of 3
      • First switch off your phone and remove the SIM card tray.
      • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
      • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
      Ask FixBot
    2. Huawei P9 Front Facing Camera Replacement: step 2, image 1 of 2 Huawei P9 Front Facing Camera Replacement: step 2, image 2 of 2
      • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
      • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
      • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
      • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
      Ask FixBot
    3. Huawei P9 Front Facing Camera Replacement, Fingerprint sensor: step 3, image 1 of 2 Huawei P9 Front Facing Camera Replacement, Fingerprint sensor: step 3, image 2 of 2
      • Disconnect the fingerprint sensor using a spudger.
      Ask FixBot
    1. Huawei P9 Front Facing Camera Replacement, Front Facing Camera: step 4, image 1 of 3 Huawei P9 Front Facing Camera Replacement, Front Facing Camera: step 4, image 2 of 3 Huawei P9 Front Facing Camera Replacement, Front Facing Camera: step 4, image 3 of 3
      • Peel off the conducting fabric.
      • You will have to transfer it to the new camera (careful it's sticky).
      • Unplug the camera connector.
      • Now you can remove the front camera.
      Ask FixBot
Author
with
Dominik Schnabelrauch
268,200 Reputation
682 Guides authored
iFixit EU Team Member of iFixit EU Team
Staff
36 Members
3,072 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 111
All Time: 2,679
