Huawei P9 Earpiece Speaker Replacement
  1. Huawei P9 Earpiece Speaker Replacement, Back Cover: step 1, image 1 of 3 Huawei P9 Earpiece Speaker Replacement, Back Cover: step 1, image 2 of 3 Huawei P9 Earpiece Speaker Replacement, Back Cover: step 1, image 3 of 3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Earpiece Speaker Replacement: step 2, image 1 of 2 Huawei P9 Earpiece Speaker Replacement: step 2, image 2 of 2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Earpiece Speaker Replacement, Fingerprint sensor: step 3, image 1 of 2 Huawei P9 Earpiece Speaker Replacement, Fingerprint sensor: step 3, image 2 of 2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Earpiece Speaker Replacement, Earpiece Speaker: step 4, image 1 of 3 Huawei P9 Earpiece Speaker Replacement, Earpiece Speaker: step 4, image 2 of 3 Huawei P9 Earpiece Speaker Replacement, Earpiece Speaker: step 4, image 3 of 3
    • Loosen the seven Phillips #00 screws on the motherboard.
    • On one of them might be a sticker. Remove it.
    • Unplug the antenna cable.
    • The metal plate covering the battery connector has two little hooks on each side. Use a tweezer to free them and unhinge the plate towards the top.
  5. Huawei P9 Earpiece Speaker Replacement: step 5, image 1 of 2 Huawei P9 Earpiece Speaker Replacement: step 5, image 2 of 2
    • Disconnect the volume button cable and the display cable …
  6. Huawei P9 Earpiece Speaker Replacement: step 6, image 1 of 2 Huawei P9 Earpiece Speaker Replacement: step 6, image 2 of 2
    • … as well as the battery connector and the cable running to the daughter board.
  7. Huawei P9 Earpiece Speaker Replacement: step 7, image 1 of 2 Huawei P9 Earpiece Speaker Replacement: step 7, image 2 of 2
    • Now you can lift out the motherboard to access the earpiece speaker.
    • Be careful with both cameras since they are still connected to the motherboard.
    • The earpiece speaker ist fixed with an adhesive foam gasket.
Dominik Schnabelrauch
258,048 Reputation
682 Guides authored
iFixit EU Team Member of iFixit EU Team
Staff
37 Members
1,226 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 92
All Time: 2,908
