Huawei P9 Charging Board Replacement
    1. Huawei P9 Charging Board Replacement, Back Cover: step 1, image 1 of 3 Huawei P9 Charging Board Replacement, Back Cover: step 1, image 2 of 3 Huawei P9 Charging Board Replacement, Back Cover: step 1, image 3 of 3
      • First switch off your phone and remove the SIM card tray.
      • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
      • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
      Ask FixBot
    2. Huawei P9 Charging Board Replacement: step 2, image 1 of 2 Huawei P9 Charging Board Replacement: step 2, image 2 of 2
      • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
      • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
      • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
      • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
      Ask FixBot
    3. Huawei P9 Charging Board Replacement, Fingerprint sensor: step 3, image 1 of 2 Huawei P9 Charging Board Replacement, Fingerprint sensor: step 3, image 2 of 2
      • Disconnect the fingerprint sensor using a spudger.
      Ask FixBot
    1. Huawei P9 Charging Board Replacement, lower section: step 4, image 1 of 3 Huawei P9 Charging Board Replacement, lower section: step 4, image 2 of 3 Huawei P9 Charging Board Replacement, lower section: step 4, image 3 of 3
      • Undo the three Phillips #00 screws.
      • Disconnect the loudspeaker flex connector.
      • Carefully remove the metal bracket.
      • Mind the adhesive underneath that might stick to the headphone connector.
      Ask FixBot
    2. Huawei P9 Charging Board Replacement: step 5, image 1 of 3 Huawei P9 Charging Board Replacement: step 5, image 2 of 3 Huawei P9 Charging Board Replacement: step 5, image 3 of 3
      • Disconnect the motherboard flex cable and the antenna cable.
      • Unplug the headphone jack connector.
      Ask FixBot
    1. Huawei P9 Charging Board Replacement, Charging Board: step 6, image 1 of 1
      • Now you can easily remove the charging board.
      Ask FixBot
8 other people completed this guide.
Dominik Schnabelrauch
266,047 Reputation
682 Guides authored
iFixit EU Team Member of iFixit EU Team
Staff
37 Members
3,072 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 113
All Time: 8,301
