Up to 20% off select tools
Huawei P9 Battery Replacement
Views: 132K
View statistics:
Past 24 Hours:
6
Past 7 Days:
39
Past 30 Days:
245
All Time:
132,049
Comments: 79
50 comments on steps, 29 guide comments.
Go to guide comments
Completed: 93
93 people have marked this guide "completed." Will you be next?
Favorites: 13
13 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the battery in your Huawei P9 smartphone.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
    1. Huawei P9 Battery Replacement, Back Cover: step 1, image 1 of 3 Huawei P9 Battery Replacement, Back Cover: step 1, image 2 of 3 Huawei P9 Battery Replacement, Back Cover: step 1, image 3 of 3
      • First switch off your phone and remove the SIM card tray.
      • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
      • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
      Ask FixBot
    2. Huawei P9 Battery Replacement: step 2, image 1 of 2 Huawei P9 Battery Replacement: step 2, image 2 of 2
      • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
      • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
      • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
      • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
      Ask FixBot
    3. Huawei P9 Battery Replacement, Fingerprint sensor: step 3, image 1 of 2 Huawei P9 Battery Replacement, Fingerprint sensor: step 3, image 2 of 2
      • Disconnect the fingerprint sensor using a spudger.
      Ask FixBot
    1. Huawei P9 Battery Replacement, Battery: step 4, image 1 of 3 Huawei P9 Battery Replacement, Battery: step 4, image 2 of 3 Huawei P9 Battery Replacement, Battery: step 4, image 3 of 3
      • Unplug the antenna cable.
      • Remove the sticker that sits on top of the screw.
      Ask FixBot
    2. Huawei P9 Battery Replacement: step 5, image 1 of 3 Huawei P9 Battery Replacement: step 5, image 2 of 3 Huawei P9 Battery Replacement: step 5, image 3 of 3
      • Unscrew the two Phillips #00 screws that hold the metal plate in place.
      • The plate, which is covering the battery connector, has two little hooks on each side. Use a tweezer to free them and unhinge the plate by carefully moving it upwards.
      Ask FixBot
    3. Huawei P9 Battery Replacement: step 6, image 1 of 2 Huawei P9 Battery Replacement: step 6, image 2 of 2
      • Now you can unplug the battery connector and bend it aside.
      • The EVA-L09 model has an NFC antenna adhered onto the battery.
      • If you are just removing the battery to get to the display, you can leave the NFC on the battery.
      • Mark its place on the battery with a felt pen for reassembly. Carefully peel it off and make sure not to rip or crease the antenna.
      • For reassembly, place the NFC antenna on the battery where it was before so its contacts align with their counterparts.
      Ask FixBot
    4. Huawei P9 Battery Replacement: step 7, image 1 of 2 Huawei P9 Battery Replacement: step 7, image 2 of 2
      • Free the ends of the adhesive pull tabs to get a good grip on them.
      Ask FixBot
    5. Huawei P9 Battery Replacement: step 8, image 1 of 3 Huawei P9 Battery Replacement: step 8, image 2 of 3 Huawei P9 Battery Replacement: step 8, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • The battery is secured with three pieces of adhesive, a removable pull-tab in the center, and on the SIM tray side. A third piece of adhesive on the button side has no pull-tab.
      • Pull the adhesive tabs in a slow constant movement to free the battery.
      • Should those adhesive tabs snap, you might want to use an iOpener to heat and soften them a little bit so you can pry out the battery with a spudger.
      • There are two cables running directly underneath the battery. Take care not to damage them when prying with a spudger! You can see their position in the last picture.
      • Slowly lift the battery toward the button side and free it from the remaining hidden piece of adhesive.
      • When reassembling your phone, replace old adhesive with stretch release adhesive strips, double-sided tape, or pre-cut adhesive strips.
      Ask FixBot
93 other people completed this guide.
Author
with
Tobias Isakeit
136,836 Reputation
189 Guides authored
29 Guide Comments
Just FYI, My replacement battery from Huawei doesn’t fit. The cable doesn’t reach the connector. Soldering Required!
https://imgur.com/gallery/vTsX8
dallebull - Reply Share
Bonjour j es effectué cette opération.J es changé le connecteur de chargeur complet suite à un dysfonctionnement. Et la batterie aussi.Et mon soucis reste le même. Le téléphone s allumé mais pas de voyant de charge.merci de me renseigner.
Berhault - Reply Share
Bonjour,
J’ai le même problème , avez-vous trouvé une solution ?
Amenis - Reply Share
J'ai le même problème quand je charge sa passe mais le pourcentage n'augmente pas
300elmoise - Reply Share
Bonjour suite à une panne avec mon huawei p9 j es changé le connecteur de chargeur et la batterie et mon problèmereste toujours le même. Il charge toujours pas.merci de me
Past 24 Hours: 6
Past 7 Days: 39
Past 30 Days: 245
All Time: 132,049
