Up to 20% off select tools
Huawei P9 Back Cover
Views: 11K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
138
All Time:
10,630
Comments: 25
24 comments on steps, 1 guide comment.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to open your Huawei P9 smartphone.
    1. Huawei P9 Back Cover, Back Cover: step 1, image 1 of 3 Huawei P9 Back Cover, Back Cover: step 1, image 2 of 3 Huawei P9 Back Cover, Back Cover: step 1, image 3 of 3
      • First switch off your phone and remove the SIM card tray.
      • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
      • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
      Ask FixBot
    2. Huawei P9 Back Cover: step 2, image 1 of 2 Huawei P9 Back Cover: step 2, image 2 of 2
      • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
      • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
      • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
      • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
      Ask FixBot
    3. Huawei P9 Back Cover, Fingerprint sensor: step 3, image 1 of 2 Huawei P9 Back Cover, Fingerprint sensor: step 3, image 2 of 2
      • Disconnect the fingerprint sensor using a spudger.
      Ask FixBot
8 other people completed this guide.
Author
with
Tobias Isakeit
136,836 Reputation
189 Guides authored
1 Guide Comment
I cant open the phone
Chizu - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 138
All Time: 10,630
