Huawei P8 Lite Motherboard Replacement
    1. Huawei P8 Lite Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Remove the SIM card tray.
      • Use the SIM Card Eject Tool to click the pins located in two small holes on the side of the phone.
      Ask FixBot
    2. Huawei P8 Lite Motherboard Replacement: step 2, image 1 of 1
      • Remove the back cover.
      • The cover is not fastened with screws or adhesive, so you can use your finger nails, plastic spudger or other tools.
      Ask FixBot
    3. Huawei P8 Lite Motherboard Replacement: step 3, image 1 of 1
      • Use the screwdrivers from 54 Bit Driver Kit to undo the screws. Be sure to keep the screws separated on your work surface to avoid confusion during the assembly.
      • PH000 Bit
      • T5 Torx
      Ask FixBot
    4. Huawei P8 Lite Motherboard Replacement: step 4, image 1 of 1
      • Gently pull the connectors attached to the motherboard to disconnect them. See the highlighted areas in the photos.
      • These connectors are extremely fragile, so avoid using any kind of tools and make sure to be extremely gentle in the process.
      Ask FixBot
    5. Huawei P8 Lite Motherboard Replacement: step 5, image 1 of 1
      • Remove the motherboard carefully.
      • Replace the motherboard with the new one. To reassempble the phone, follow the teardown process guide in the reverse order.
      Ask FixBot
8 other people completed this guide.
Brayden Mann
645 Reputation
4 Guides authored
Metro State, Team 1-2, Carpenter Spring 2016 Member of Metro State, Team 1-2, Carpenter Spring 2016
MSU-CARPENTER-S16S1G2
3 Members
60 Guides authored
4 Guide Comments
Anywhere to buy this motherboard? Maybe display as well?
Jan Šinkovec - Reply Share
mine also need a new mother
anywr l can get it asap
blessed - Reply Share
Hey
I need p8 lite motherboard
goitsemodimo - Reply Share
I had to resort to some tips on how to disassemble P8 LITE to change the micro usb charger. Thanks for sharing.
Alvaro Gomes - Reply Share
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 106
All Time: 8,789
