Huawei P8 Lite Loudspeaker Replacement
    1. Huawei P8 Lite Loudspeaker Replacement, Remove  Back Cover and Loudspeaker: step 1, image 1 of 2 Huawei P8 Lite Loudspeaker Replacement, Remove  Back Cover and Loudspeaker: step 1, image 2 of 2
      Tool used on this step:
      Spudger
      $2.99
      Buy
      • Use the Spudger tool to get access to the loudspeaker. Locate where the headphone jack is, then move about one-inch to the right and begin to gently pry the back-cover off the phone with the flat end of the Spudger tool. Make sure to pry apart the entire perimeter of the back-cover to prevent bending/cracking of the plastic.
      • Tools used: Spudger tool (used as a wedge to pry off the back-cover and loudspeaker.)
      Ask FixBot
    2. Huawei P8 Lite Loudspeaker Replacement: step 2, image 1 of 1
      • Remove three silver Phillips 000 screws.
      • Remove four T5 Torx screws.
      Ask FixBot
    3. Huawei P8 Lite Loudspeaker Replacement: step 3, image 1 of 2 Huawei P8 Lite Loudspeaker Replacement: step 3, image 2 of 2
      Spudger
      $2.99
      Buy
      • Gently, use the flat end of the Spudger tool, or a metal opening tool to lift and remove the loudspeaker from the phone. The loudspeaker is the entire portion of the phone where the screws were extracted.
      Ask FixBot
To reassemble your device, follow Teardown Guide steps 4, 3, 2, 1 in that order.
2 other people completed this guide.
Brayden Mann
645 Reputation
4 Guides authored
Metro State, Team 1-2, Carpenter Spring 2016 Member of Metro State, Team 1-2, Carpenter Spring 2016
MSU-CARPENTER-S16S1G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 98
All Time: 1,876
