Up to 20% off select tools
Huawei P8 Front Camera Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
99
All Time:
3,119
Comments: 0
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the front camera in your Huawei P8.
    1. Huawei P8 Front Camera Replacement, Huawei P8 Battery Replacement: step 1, image 1 of 2 Huawei P8 Front Camera Replacement, Huawei P8 Battery Replacement: step 1, image 2 of 2
      • First switch off your phone.
      • Remove the trays for the SD card and the SIM card.
      Ask FixBot
    2. Huawei P8 Front Camera Replacement: step 2, image 1 of 3 Huawei P8 Front Camera Replacement: step 2, image 2 of 3 Huawei P8 Front Camera Replacement: step 2, image 3 of 3
      • Unscrew the two Torx T2 screws located at the bottom next to the device's micro USB port.
      • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
      • Use an iSclack or a suction handle to separate the display unit from the rear panel.
      Ask FixBot
    3. Huawei P8 Front Camera Replacement: step 3, image 1 of 2 Huawei P8 Front Camera Replacement: step 3, image 2 of 2
      • Remove the Phillips #00 screw that holds down the metal clamp covering the front camera connector.
      • Remove the metal clamp covering the flex connector of the front camera.
      Ask FixBot
    4. Huawei P8 Front Camera Replacement: step 4, image 1 of 3 Huawei P8 Front Camera Replacement: step 4, image 2 of 3 Huawei P8 Front Camera Replacement: step 4, image 3 of 3
      • Unplug the headphone jack and the front camera flex connectors.
      • Remove the front camera.
      Ask FixBot
6 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,200 Reputation
682 Guides authored
iFixit EU Team Member of iFixit EU Team
Staff
36 Members
3,072 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 99
All Time: 3,119
