Up to 20% off select tools
Huawei P8 Display Replacement
Views: 19K
View statistics:
Past 24 Hours:
3
Past 7 Days:
25
Past 30 Days:
118
All Time:
19,189
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to remove and replace the display of a Huawei P8.
    1. Huawei P8 Display Replacement, Display: step 1, image 1 of 2 Huawei P8 Display Replacement, Display: step 1, image 2 of 2
      • First switch off your phone.
      • Remove the trays for the SD card and the SIM card.
      Ask FixBot
    2. Huawei P8 Display Replacement: step 2, image 1 of 1
      • Remove the two Torx T2 screws located at the bottom next to the micro USB port.
      • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
      Ask FixBot
    3. Huawei P8 Display Replacement: step 3, image 1 of 2 Huawei P8 Display Replacement: step 3, image 2 of 2
      • Use an iSclack or a suction handle to separate the display unit from the rear panel.
      Ask FixBot
    4. Huawei P8 Display Replacement: step 4, image 1 of 1
      • Remove the two Phillips #00 that hold down the two metal clamps covering the front camera, the display and battery flex connectors.
      Ask FixBot
    5. Huawei P8 Display Replacement: step 5, image 1 of 3 Huawei P8 Display Replacement: step 5, image 2 of 3 Huawei P8 Display Replacement: step 5, image 3 of 3
      • Use a tweezer to remove the metal clamp covering the display and the battery flex connector.
      • Unplug the battery flex connector with a Spudger.
      • Remove the metal clamp covering the flex connector of the front camera.
      Ask FixBot
    6. Huawei P8 Display Replacement: step 6, image 1 of 3 Huawei P8 Display Replacement: step 6, image 2 of 3 Huawei P8 Display Replacement: step 6, image 3 of 3
      • Unplug the headphone jack and the front camera flex connectors.
      • Remove the front camera.
      Ask FixBot
    7. Huawei P8 Display Replacement: step 7, image 1 of 3 Huawei P8 Display Replacement: step 7, image 2 of 3 Huawei P8 Display Replacement: step 7, image 3 of 3
      • Unscrew the four Phillips #00 screws that hold down the motherboard of your Huawei P8.
      • Unplug the vibration motor flex connector.
      • Disconnect the antenna cable.
      Ask FixBot
    8. Huawei P8 Display Replacement: step 8, image 1 of 3 Huawei P8 Display Replacement: step 8, image 2 of 3 Huawei P8 Display Replacement: step 8, image 3 of 3
      • Unplug the display flex connector from the main board with a Spudger.
      • Disconnect and remove the antenna cable with a tweezer.
      Ask FixBot
    9. Huawei P8 Display Replacement: step 9, image 1 of 2 Huawei P8 Display Replacement: step 9, image 2 of 2
      • Use a spudger to disconnect the flex cable of the power and volume buttons.
      • Remove the liquid contact indicator that sits on top of the last screw holding down your main board.
      Ask FixBot
    10. Huawei P8 Display Replacement: step 10, image 1 of 2 Huawei P8 Display Replacement: step 10, image 2 of 2
      • Unscrew the Phillips #00 screw.
      • Lift up the main board with a spudger and remove it.
      Ask FixBot
    11. Huawei P8 Display Replacement: step 11, image 1 of 3 Huawei P8 Display Replacement: step 11, image 2 of 3 Huawei P8 Display Replacement: step 11, image 3 of 3
      • Remove the adhesive tape which is covering the display flex cable.
      • Loosen the adhesive around the mid frame with an iOpener.
      • In particular take care of the adhesive under the top and bottom of the display.
      • When the glue is softened you can use a spudger to get behind the display through the camera bay and get between the frame and the display.
      Ask FixBot
    12. Huawei P8 Display Replacement: step 12, image 1 of 3 Huawei P8 Display Replacement: step 12, image 2 of 3 Huawei P8 Display Replacement: step 12, image 3 of 3
      • Insert an opening pick in the gap where you separated the display from the mid frame.
      • Insert just the tip of the opening pick and slide it along the right side to separate the display from the frame.
      Ask FixBot
    13. Huawei P8 Display Replacement: step 13, image 1 of 2 Huawei P8 Display Replacement: step 13, image 2 of 2
      • Insert another opening pick at the top of the phone and loosen the adhesive under the upper part of the display.
      Ask FixBot
    14. Huawei P8 Display Replacement: step 14, image 1 of 3 Huawei P8 Display Replacement: step 14, image 2 of 3 Huawei P8 Display Replacement: step 14, image 3 of 3
      • Insert just the tip of the opening pick and slide it along the left side of the phone to separate the display from the frame.
      Ask FixBot
    15. Huawei P8 Display Replacement: step 15, image 1 of 2 Huawei P8 Display Replacement: step 15, image 2 of 2
      • Loosen the adhesive under the bottom part of the display unit with the opening pick.
      • Flip the opening pick a little to separate the display from the mid frame.
      • If you notice that there is still some adhesive which isn't loosened, use the iOpener to loosen it and slide once more along the mid frame with an opening pick.
      Ask FixBot
    16. Huawei P8 Display Replacement: step 16, image 1 of 2 Huawei P8 Display Replacement: step 16, image 2 of 2
      • Lift up the display and remove it.
      • The display flex cable should easily go through the recess in the mid frame while removing the display.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary.
10 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,200 Reputation
682 Guides authored
iFixit EU Team Member of iFixit EU Team
Staff
36 Members
3,072 Guides authored
2 Guide Comments
Is there any difference on screen frame between GRA-L09 and GRA-TL10??? The l09 is the single sim and the TL10 is the dual sim…
Rafail Petridis - Reply Share
installing a new screen the first time, i was looking at darkness. then, taking it apart again and taking away the protective foil on the back of the screen, it just showed pink/purple colors and started heating up pretty bad around the charging connector. my idea would be a short circuit. any idea what is going wrong and can this still be saved?
Albert Einbein - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 118
All Time: 19,189
