Up to 20% off select tools
Huawei P7 Screen Assembly Replacement
Views: 44K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
140
All Time:
44,246
Comments: 12
12 guide comments.
Go to guide comments
Completed: 26
26 people have marked this guide "completed." Will you be next?
Favorites: 19
19 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Repairing a broken screen of the Huawei P7 is a much less daunting task than it was with its predecessor.
    1. Huawei P7 Screen Assembly Replacement, Front Display Assembly: step 1, image 1 of 1
      • Cracked screen, but no idea how to start?
      • Keep calm
      • Follow my guide
      Ask FixBot
    2. Huawei P7 Screen Assembly Replacement: step 2, image 1 of 3 Huawei P7 Screen Assembly Replacement: step 2, image 2 of 3 Huawei P7 Screen Assembly Replacement: step 2, image 3 of 3
      • Heat the glass panel on the back to around 85°C so the adhesive loosens
      • Use a plastic spudger or opening tool to gently pry up the glass
      • Carefully work your way around the edges
      • Be careful at the bottom. There is a flex cable running near the back-glass
      • Never use metal tools for this. Metal will scratch the black paint off the backplate
      Ask FixBot
    3. Huawei P7 Screen Assembly Replacement: step 3, image 1 of 3 Huawei P7 Screen Assembly Replacement: step 3, image 2 of 3 Huawei P7 Screen Assembly Replacement: step 3, image 3 of 3
      • First, we'll disconnect the battery cable
      • Use a philips screwdriver to remove the shield, revealing the battery connection
      • Next, disconnect the LCD/Digitizer ribbon
      Ask FixBot
    4. Huawei P7 Screen Assembly Replacement: step 4, image 1 of 2 Huawei P7 Screen Assembly Replacement: step 4, image 2 of 2
      • Remove the battery
      • Use plastic tools to pry the battery off its adhesive
      • Patience is key here
      • Don't bend, puncture or heat the battery.
      Ask FixBot
    5. Huawei P7 Screen Assembly Replacement: step 5, image 1 of 2 Huawei P7 Screen Assembly Replacement: step 5, image 2 of 2
      • Heat the front side to about 85°C
      • Using a plastic tool, seperate the display from the frame, but don't pull it too far away.
      Ask FixBot
    6. Huawei P7 Screen Assembly Replacement: step 6, image 1 of 2 Huawei P7 Screen Assembly Replacement: step 6, image 2 of 2
      • Flipping the phone over, we can see the display ribbon
      • Make sure none of this cable is stuck to the frame
      Ask FixBot
    7. Huawei P7 Screen Assembly Replacement: step 7, image 1 of 2 Huawei P7 Screen Assembly Replacement: step 7, image 2 of 2
      • Pull the display ribbon through the frame
      • Make sure there is not a single glass-shard left on the frame. Any little splinter will cause significant damage to the new screen you're about to place
      Ask FixBot
    8. Huawei P7 Screen Assembly Replacement: step 8, image 1 of 2 Huawei P7 Screen Assembly Replacement: step 8, image 2 of 2
      • Tape up the whole frame with double-sided tape for a perfect fit that won't come loose
      • Make sure you don't cover important holes
      • Put the new screen in, sliding the cable first, making sure the whole cable (aswell as the little part sticking out)
      Ask FixBot
    9. Huawei P7 Screen Assembly Replacement: step 9, image 1 of 2 Huawei P7 Screen Assembly Replacement: step 9, image 2 of 2
      • As good as new
      Ask FixBot
- Never use metal opening tools
- Remove ALL the glass splinters from the frame before re-attaching the new one
- Have fun
26 other people completed this guide.
Author
with
Maxim
2,297 Reputation
3 Guides authored
iFixers Belgium Member of iFixers Belgium
Business
1 Member
36 Guides authored
12 Guide Comments
Hallo Paintskill,
Ich habe eine wesentliche Frage. Was muss ich noch beachten, wenn mein Display und das Touchpannel ganz ist und ich aber nur mein Deckglas austauschen möchte. Wie sind diese aneinander geklebt? Wie schwierig ist das?
Und ja, welche doppelseitigen Klebestreifen hast du benutzt?
lg und Danke,
Friendly
Friendly - Reply Share
Hallo,
Nun ich habs auch selber versucht und wollte sagen.
Mein Deckglas war nur gesprungen, nicht das Display. Also wollte ich daran sparen und nur das Deckglas kaufen. Keine gute Idee... Das ist brutal mit einander verklebt und selbst wenn man es abbekäme müssten wir das empfindliche Display noch vom Kleber reinigen. Das hab ich mit nicht geschafft - und ich war im Labor der Hochschule. Kauft gleich das Display ^^
lg
Friendly
PS: die 85°C zum Kleber aufheizen sind ganz vernünftig.
found nice video about this process here: https://www.youtube.com/watch?v=BD24da5b...
Karel - Reply Share
I like that helping video.Thanks pal!
Styleart - Reply Share
I like that helping video.Thanks!
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 140
All Time: 44,246
