Huawei P20 Rear Glass Replacement
    1. Huawei P20 Rear Glass Replacement, Rear Glass: step 1, image 1 of 1
      • Before you begin, switch off your phone.
      • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
      Ask FixBot
    2. Huawei P20 Rear Glass Replacement: step 2, image 1 of 3 Huawei P20 Rear Glass Replacement: step 2, image 2 of 3 Huawei P20 Rear Glass Replacement: step 2, image 3 of 3
      • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
      • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
      • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
      • Insert an opening pick into the gap.
      • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      • Slide the opening pick to the bottom right corner.
      Ask FixBot
    3. Huawei P20 Rear Glass Replacement: step 3, image 1 of 2 Huawei P20 Rear Glass Replacement: step 3, image 2 of 2
      • Insert a second opening pick and slide it to the bottom left corner to cut the adhesive.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Huawei P20 Rear Glass Replacement: step 4, image 1 of 3 Huawei P20 Rear Glass Replacement: step 4, image 2 of 3 Huawei P20 Rear Glass Replacement: step 4, image 3 of 3
      • Insert a third opening pick at the bottom left corner.
      • In the next few steps whilst cutting around the power button and rear camera make sure you only use the tip of the opening pick to avoid cutting the cable, smearing the lens or damaging the camera.
      • Start to slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
      • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Huawei P20 Rear Glass Replacement: step 5, image 1 of 2 Huawei P20 Rear Glass Replacement: step 5, image 2 of 2
      • If the adhesive becomes hard to cut it most likely cooled down. Use your iOpener to reheat it.
      • Insert a fourth opening pick under the top left corner of the back cover.
      • Slide the opening pick along the top edge of the phone to cut the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Huawei P20 Rear Glass Replacement: step 6, image 1 of 2 Huawei P20 Rear Glass Replacement: step 6, image 2 of 2
      • Insert a fifth opening pick at the top right corner of the phone.
      • Slide the opening pick along the right side to cut the remaining adhesive.
      Ask FixBot
    7. Huawei P20 Rear Glass Replacement: step 7, image 1 of 2 Huawei P20 Rear Glass Replacement: step 7, image 2 of 2
      • Lift and remove the back cover.
      • Before installing fresh adhesive and reassembling, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
      Ask FixBot
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear glass, apply pressure for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
Dominik Schnabelrauch
266,083 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
3 Guide Comments
Hi Dominic, nice guide
Nicu Gherghin - Reply Share
What size of adhesive should be used?
Jimmi Rasmussen - Reply Share
Bonjour, j'ai un nappe qui était sur l'ancienne vitre arrière et je ne la vois pas dans ce tuto 😅
Je tâcher de tout bien remettre en place mais j'aimerais bien comprendre à quoi elle sert.
Merci d'avance et bravo pour votre travail, vous êtes géniaux 👍
cyp cabs - Reply Share
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 78
All Time: 5,513
