Up to 20% off select tools
Huawei P10 Rear Camera Replacement
Views: 8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
98
All Time:
7,969
Comments: 18
10 comments on steps, 8 guide comments.
Go to guide comments
Completed: 16
16 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 35 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the rear camera in your Huawei P10 smartphone. When reassembling your phone apply new adhesive where it is necessary.
    1. Huawei P10 Rear Camera Replacement, Back Cover: step 1, image 1 of 3 Huawei P10 Rear Camera Replacement, Back Cover: step 1, image 2 of 3 Huawei P10 Rear Camera Replacement, Back Cover: step 1, image 3 of 3
      • Switch off your phone.
      • Remove the two Pentalobe P2 screws at the bottom.
      • Remove the SIM card tray.
      Ask FixBot
    2. Huawei P10 Rear Camera Replacement: step 2, image 1 of 3 Huawei P10 Rear Camera Replacement: step 2, image 2 of 3 Huawei P10 Rear Camera Replacement: step 2, image 3 of 3
      • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
      • Carefully pry the display with its parts out of the case.
      • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
      • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
      Ask FixBot
    3. Huawei P10 Rear Camera Replacement: step 3, image 1 of 2 Huawei P10 Rear Camera Replacement: step 3, image 2 of 2
      • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
      • Swing open the phone backwards.
      • Use a spudger to disconnect the power- and volume button flex cable.
      Ask FixBot
    1. Huawei P10 Rear Camera Replacement, Battery disconnect: step 4, image 1 of 3 Huawei P10 Rear Camera Replacement, Battery disconnect: step 4, image 2 of 3 Huawei P10 Rear Camera Replacement, Battery disconnect: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the Phillips #00 screw.
      • Use tweezers to remove the metal plate.
      • Use a spudger to disconnect the battery flex cable.
      Ask FixBot
    1. Huawei P10 Rear Camera Replacement, Rear Camera: step 5, image 1 of 2 Huawei P10 Rear Camera Replacement, Rear Camera: step 5, image 2 of 2
      Buy
      • Use tweezers to remove the metal shield.
      Ask FixBot
    2. Huawei P10 Rear Camera Replacement: step 6, image 1 of 3 Huawei P10 Rear Camera Replacement: step 6, image 2 of 3 Huawei P10 Rear Camera Replacement: step 6, image 3 of 3
      • Use tweezers to loosen the bottom end of the adhesive strip, that holds down the flex connector of the rear facing camera.
      • Use the flat end of a spudger to disconnect the camera flex cable.
      • Carefully remove the rear camera.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
16 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,208 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
8 Guide Comments
HI, I need to understand why many of us owners of the Huawei P10 has problems with the camera that does not focus or each photo is always blurred and it takes a side kick to fix it temporarily, then I would also know if changing the camera solve the problem. Thank you.
Jean Pierre Valli - Reply Share
where to get the best rear camera replacement?
Salihin Saealal - Reply Share
I have replaced the camera in my phone however the replacement does not work. I have seen comments from other people who have had a similar issue such as https://forum.xda-developers.com/p10/hel...
Could this be a firmware related issue? Perhaps the camera firmware in the replacement part is now older than that expected by the firmware in the phone itself?
Does anyone know where to find information about this sort of thing? Whenever I search the Googles I am always taken to generic pages about flashing boot loaders and various versions of Android, not the actual firmware.
Alex Baker - Reply Share
where I can buy this camera as long as it is original?
pedrosantiagotavares - Reply Share
What is misssing in detail: how to open the back case from the display. It was very hard and I need another webpage to get additional infromation.
Compi-Sams - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 98
All Time: 7,969
