Huawei P10 Plus Front Facing Camera Replacement
    1. Huawei P10 Plus Front Facing Camera Replacement, Display: step 1, image 1 of 3 Huawei P10 Plus Front Facing Camera Replacement, Display: step 1, image 2 of 3 Huawei P10 Plus Front Facing Camera Replacement, Display: step 1, image 3 of 3
      • Use an iOpener to loosen the adhesive beneath the display, focusing on the upper and lower part of the display.
      • Use an opening pick, or iFlex, to separate the adhesive on all sides of the display.
      • To avoid damage to the display, do not push the tool too deeply into the phone.
      Ask FixBot
    2. Huawei P10 Plus Front Facing Camera Replacement: step 2, image 1 of 3 Huawei P10 Plus Front Facing Camera Replacement: step 2, image 2 of 3 Huawei P10 Plus Front Facing Camera Replacement: step 2, image 3 of 3
      • There is a thin display cable between the screen and phone, be very careful not to rip it when opening the device.
      • Place a suction cup, or iSclack, on the upper portion of the phone and lift the display off the midframe.
      • Don't remove the display, the cable is trapped under a bracket screwed to the phone. You can flip the display to lay it down without straining the cable, or simply hold it in the next steps.
      Ask FixBot
    3. Huawei P10 Plus Front Facing Camera Replacement, Unfasten the screw: step 3, image 1 of 1
      • Remove the 3.3 mm-long Phillips screw securing the display flex connector bracket.
      Ask FixBot
    4. Huawei P10 Plus Front Facing Camera Replacement: step 4, image 1 of 3 Huawei P10 Plus Front Facing Camera Replacement: step 4, image 2 of 3 Huawei P10 Plus Front Facing Camera Replacement: step 4, image 3 of 3
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • Open the metal bracket that covers the display flex cable.
      • Use a spudger to disconnect the display flex cable.
      • Remove the display.
      • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
      Ask FixBot
    1. Huawei P10 Plus Front Facing Camera Replacement, Midframe: step 5, image 1 of 2 Huawei P10 Plus Front Facing Camera Replacement, Midframe: step 5, image 2 of 2
      • Remove the 13 Phillips #00 screws.
      • Remove the metal shield which holds down the display flex connector.
      Ask FixBot
    2. Huawei P10 Plus Front Facing Camera Replacement: step 6, image 1 of 3 Huawei P10 Plus Front Facing Camera Replacement: step 6, image 2 of 3 Huawei P10 Plus Front Facing Camera Replacement: step 6, image 3 of 3
      • Remove the SIM card tray.
      • Use the pointed end of a spudger to pry out the mid frame until you can get a good grip.
      Ask FixBot
    3. Huawei P10 Plus Front Facing Camera Replacement: step 7, image 1 of 3 Huawei P10 Plus Front Facing Camera Replacement: step 7, image 2 of 3 Huawei P10 Plus Front Facing Camera Replacement: step 7, image 3 of 3
      • Remove the mid frame.
      • Disconnect the battery flex cable with a spudger.
      Ask FixBot
    1. Huawei P10 Plus Front Facing Camera Replacement, Front Facing Camera: step 8, image 1 of 3 Huawei P10 Plus Front Facing Camera Replacement, Front Facing Camera: step 8, image 2 of 3 Huawei P10 Plus Front Facing Camera Replacement, Front Facing Camera: step 8, image 3 of 3
      • Peel of the adhesive tape that connects the front facing camera to the mainboard.
      • Use a spudger to disconnect the front camera flex cable.
      • Remove the front camera.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Dominik Schnabelrauch
266,047 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,713 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 22
Past 30 Days: 75
All Time: 1,549
