Huawei P10 Lite Charging Board Replacement
    1. Huawei P10 Lite Charging Board Replacement, Back cover: step 1, image 1 of 3 Huawei P10 Lite Charging Board Replacement, Back cover: step 1, image 2 of 3 Huawei P10 Lite Charging Board Replacement, Back cover: step 1, image 3 of 3
      • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
      • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
      • If the adhesive is hard to cut, use an iOpener to loosen it.
      Ask FixBot
    2. Huawei P10 Lite Charging Board Replacement: step 2, image 1 of 3 Huawei P10 Lite Charging Board Replacement: step 2, image 2 of 3 Huawei P10 Lite Charging Board Replacement: step 2, image 3 of 3
      • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
      • Flip the rear cover over to the right side of the phone.
      Ask FixBot
    3. Huawei P10 Lite Charging Board Replacement: step 3, image 1 of 2 Huawei P10 Lite Charging Board Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the sticker.
      • Remove the two Phillips #00 screws.
      • Remove the four 2.5 mm Phillips #00 screws.
      Ask FixBot
    4. Huawei P10 Lite Charging Board Replacement: step 4, image 1 of 2 Huawei P10 Lite Charging Board Replacement: step 4, image 2 of 2
      • Use tweezers to remove the mainboard shield.
      • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
      • When reassembling apply new adhesive where it is necessary.
      Ask FixBot
    1. Huawei P10 Lite Charging Board Replacement, Battery Disconnection: step 5, image 1 of 3 Huawei P10 Lite Charging Board Replacement, Battery Disconnection: step 5, image 2 of 3 Huawei P10 Lite Charging Board Replacement, Battery Disconnection: step 5, image 3 of 3
      • Remove the Phillips screw holding the battery connector plate in place.
      • Remove the battery connector plate.
      • Use the flat end of a spudger to disconnect the battery flex cable.
      Ask FixBot
    1. Huawei P10 Lite Charging Board Replacement, Loudspeaker / Vibration Motor: step 6, image 1 of 1
      • Remove the seven Philipps #000 screws.
      Ask FixBot
    2. Huawei P10 Lite Charging Board Replacement: step 7, image 1 of 3 Huawei P10 Lite Charging Board Replacement: step 7, image 2 of 3 Huawei P10 Lite Charging Board Replacement: step 7, image 3 of 3
      • Insert an opening pick under the right edge of the loudspeaker unit and lever it up.
      • Grab the loudspeaker unit and remove it.
      Ask FixBot
    3. Huawei P10 Lite Charging Board Replacement: step 8, image 1 of 2 Huawei P10 Lite Charging Board Replacement: step 8, image 2 of 2
      • Use an iOpener to loosen the glue under the vibration motor.
      • Remove the vibration motor.
      Ask FixBot
    1. Huawei P10 Lite Charging Board Replacement, Charging Board: step 9, image 1 of 2 Huawei P10 Lite Charging Board Replacement, Charging Board: step 9, image 2 of 2
      Buy
      • Use the flat end of a spudger to disconnect the interconnect cable.
      • Use tweezers to disconnect the antenna cable.
      Ask FixBot
    2. Huawei P10 Lite Charging Board Replacement: step 10, image 1 of 2 Huawei P10 Lite Charging Board Replacement: step 10, image 2 of 2
      • Use an iOpener to loosen the adhesive under the charging board.
      • Remove the charging board.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
6 other people completed this guide.
Dominik Schnabelrauch
263,708 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,581 Guides authored
3 Guide Comments
thanks and very nice
mj41574 - Reply Share
thanks to all team
p10 lite charging ic change daigram
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 56
All Time: 11,381
