Huawei P10 Lite Back cover Replacement
    1. Huawei P10 Lite Back cover Replacement, Back cover: step 1, image 1 of 3 Huawei P10 Lite Back cover Replacement, Back cover: step 1, image 2 of 3 Huawei P10 Lite Back cover Replacement, Back cover: step 1, image 3 of 3
      • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
      • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
      • If the adhesive is hard to cut, use an iOpener to loosen it.
      Ask FixBot
    2. Huawei P10 Lite Back cover Replacement: step 2, image 1 of 3 Huawei P10 Lite Back cover Replacement: step 2, image 2 of 3 Huawei P10 Lite Back cover Replacement: step 2, image 3 of 3
      • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
      • Flip the rear cover over to the right side of the phone.
      Ask FixBot
    3. Huawei P10 Lite Back cover Replacement: step 3, image 1 of 2 Huawei P10 Lite Back cover Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the sticker.
      • Remove the two Phillips #00 screws.
      • Remove the four 2.5 mm Phillips #00 screws.
      Ask FixBot
    4. Huawei P10 Lite Back cover Replacement: step 4, image 1 of 2 Huawei P10 Lite Back cover Replacement: step 4, image 2 of 2
      • Use tweezers to remove the mainboard shield.
      • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
      • When reassembling apply new adhesive where it is necessary.
      Ask FixBot
15 other people completed this guide.
Dominik Schnabelrauch
266,119 Reputation
682 Guides authored
6 Guide Comments
Great guide, but how do I move the fingerprint sensor to the new cover?
mela ross - Reply Share
You need to warm the adhesive so it can be loose
Adwell Cellular - Reply Share
What adhesive should I use? Thank you!
Calin GV - Reply Share
Nice guide! Thanks! I got a little question about the coloring of the back panel. What kind of coloring is it? Is it a coating you can take off, or is it more like a layer of paint you can scrape off? I am wondering, because I want to clear the back of my Huawei P10 lite. I hope it’s possible though.
Daan - Reply Share
Can you send me please back cover.
I'm from Nepal .
Md Usman - Reply Share
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 108
All Time: 41,520
