Huawei P10 Headphone Jack Replacement
    1. Huawei P10 Headphone Jack Replacement, Back Cover: step 1, image 1 of 3 Huawei P10 Headphone Jack Replacement, Back Cover: step 1, image 2 of 3 Huawei P10 Headphone Jack Replacement, Back Cover: step 1, image 3 of 3
      • Switch off your phone.
      • Remove the two Pentalobe P2 screws at the bottom.
      • Remove the SIM card tray.
      Ask FixBot
    2. Huawei P10 Headphone Jack Replacement: step 2, image 1 of 3 Huawei P10 Headphone Jack Replacement: step 2, image 2 of 3 Huawei P10 Headphone Jack Replacement: step 2, image 3 of 3
      • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
      • Carefully pry the display with its parts out of the case.
      • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
      • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
      Ask FixBot
    3. Huawei P10 Headphone Jack Replacement: step 3, image 1 of 2 Huawei P10 Headphone Jack Replacement: step 3, image 2 of 2
      • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
      • Swing open the phone backwards.
      • Use a spudger to disconnect the power- and volume button flex cable.
      Ask FixBot
    1. Huawei P10 Headphone Jack Replacement, Battery disconnect: step 4, image 1 of 3 Huawei P10 Headphone Jack Replacement, Battery disconnect: step 4, image 2 of 3 Huawei P10 Headphone Jack Replacement, Battery disconnect: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the Phillips #00 screw.
      • Use tweezers to remove the metal plate.
      • Use a spudger to disconnect the battery flex cable.
      Ask FixBot
    1. Huawei P10 Headphone Jack Replacement, Headphone Jack: step 5, image 1 of 2 Huawei P10 Headphone Jack Replacement, Headphone Jack: step 5, image 2 of 2
      Buy
      • Remove the three Phillips #00 screws.
      Ask FixBot
    2. Huawei P10 Headphone Jack Replacement: step 6, image 1 of 2 Huawei P10 Headphone Jack Replacement: step 6, image 2 of 2
      • Use the flat end of a spudger to disconnect the headphone jack.
      • Remove the headphone jack.
      • There is a small piece of adhesive underneath, so it might be a little bit sticky. You can use an iOpener to loosen the adhesive and make the removal easier.
      • When reassembling apply new adhesive where it's necessary.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
2 other people completed this guide.
Dominik Schnabelrauch
263,543 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,578 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 3,430
