Up to 20% off select tools
Huawei P10 Display Replacement
Views: 29K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
133
All Time:
29,468
Comments: 24
20 comments on steps, 4 guide comments.
Go to guide comments
Completed: 24
24 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to remove and replace the display in your Huawei P10 smartphone.
To protect your eyes from glass shreds and get a better grip to open the phone you might want to apply some tape onto the screen.
When reassembling apply new adhesive where it is necessary.
    1. Huawei P10 Display Replacement, Back Cover: step 1, image 1 of 3 Huawei P10 Display Replacement, Back Cover: step 1, image 2 of 3 Huawei P10 Display Replacement, Back Cover: step 1, image 3 of 3
      • Switch off your phone.
      • Remove the two Pentalobe P2 screws at the bottom.
      • Remove the SIM card tray.
      Ask FixBot
    2. Huawei P10 Display Replacement: step 2, image 1 of 3 Huawei P10 Display Replacement: step 2, image 2 of 3 Huawei P10 Display Replacement: step 2, image 3 of 3
      • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
      • Carefully pry the display with its parts out of the case.
      • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
      • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
      Ask FixBot
    3. Huawei P10 Display Replacement: step 3, image 1 of 2 Huawei P10 Display Replacement: step 3, image 2 of 2
      • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
      • Swing open the phone backwards.
      • Use a spudger to disconnect the power- and volume button flex cable.
      Ask FixBot
    1. Huawei P10 Display Replacement, Main and display flex disconnect: step 4, image 1 of 3 Huawei P10 Display Replacement, Main and display flex disconnect: step 4, image 2 of 3 Huawei P10 Display Replacement, Main and display flex disconnect: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the two Phillips #00 screws.
      • Use tweezers to remove both metal plates.
      Ask FixBot
    2. Huawei P10 Display Replacement: step 5, image 1 of 3 Huawei P10 Display Replacement: step 5, image 2 of 3 Huawei P10 Display Replacement: step 5, image 3 of 3
      • Use a spudger to disconnect the interconnect, the battery and the display flex cable.
      Ask FixBot
    1. Huawei P10 Display Replacement, Charging Board: step 6, image 1 of 2 Huawei P10 Display Replacement, Charging Board: step 6, image 2 of 2
      Buy
      • Remove the four Phillips #00 screws.
      • Use Tweezers to remove the metal plate.
      Ask FixBot
    2. Huawei P10 Display Replacement: step 7, image 1 of 2 Huawei P10 Display Replacement: step 7, image 2 of 2
      • Use a spudger to disconnect the main flex cable.
      • Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
      Ask FixBot
    3. Huawei P10 Display Replacement: step 8, image 1 of 2 Huawei P10 Display Replacement: step 8, image 2 of 2
      • Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
      Ask FixBot
    4. Huawei P10 Display Replacement: step 9, image 1 of 2 Huawei P10 Display Replacement: step 9, image 2 of 2
      • Do not damage any components sitting on the charging board while removing it.
      • Use a spudger to pry out the charging board.
      • Remove the charging board.
      Ask FixBot
    1. Huawei P10 Display Replacement, Loudspeaker: step 10, image 1 of 2 Huawei P10 Display Replacement, Loudspeaker: step 10, image 2 of 2
      • Only insert the spudger as deep as 1/16 of an inch to avoid damage.
      • Use a spudger to carefully pry out the loudspeaker. There is some adhesive underneath so it might be a little bit sticky. You can use an iOpener to loosen it.
      • Remove the loudspeaker.
      • When reassembling your phone, apply new adhesive where it's necessary.
      Ask FixBot
    1. Huawei P10 Display Replacement, Display: step 11, image 1 of 2 Huawei P10 Display Replacement, Display: step 11, image 2 of 2
      Buy
      • Remove the antenna cable if you haven't already.
      • Use tweezers to remove the interconnect cable.
      • Use an iOpener to loosen the adhesive beneath the display. Especially take care of the upper and lower part of the display.
      Ask FixBot
    2. Huawei P10 Display Replacement: step 12, image 1 of 3 Huawei P10 Display Replacement: step 12, image 2 of 3 Huawei P10 Display Replacement: step 12, image 3 of 3
      • Insert the tip of an opening pick between the display and the midframe on the bottom of the phone, near the home button.
      • Slide the opening pick along the bottom edge, to cut the adhesive.
      • Slide the opening pick to the bottom right corner and leave it there.
      • Insert another opening pick under the screen on the bottom left corner.
      Ask FixBot
    3. Huawei P10 Display Replacement: step 13, image 1 of 3 Huawei P10 Display Replacement: step 13, image 2 of 3 Huawei P10 Display Replacement: step 13, image 3 of 3
      • Slide the opening pick under the screen around all edges of the phone.
      • If the adhesive gets tough to pry it is likely too cold. Use your iOpener or heat gun to reheat it.
      Ask FixBot
    4. Huawei P10 Display Replacement: step 14, image 1 of 2 Huawei P10 Display Replacement: step 14, image 2 of 2
      • Carefully pull the display assembly away from the frame.
      • Remove the display assembly.
      Ask FixBot
24 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,200 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
4 Guide Comments
Any advice which adhesive to use? I’ve seen a russian replacement video, it looked like the guy was using some kind of silicone.
Tom My - Reply Share
I used B-7000 glue. It enables you to release the screen when a second replacement is needed.
teunkeusters - Reply Share
Assuming I purchase a screen off of ebay, and replace it using this method, will the touch id still work?
Simon Fisher - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 133
All Time: 29,468
