Huawei P10 Charging Board Replacement
    1. Huawei P10 Charging Board Replacement, Back Cover: step 1, image 1 of 3 Huawei P10 Charging Board Replacement, Back Cover: step 1, image 2 of 3 Huawei P10 Charging Board Replacement, Back Cover: step 1, image 3 of 3
      • Switch off your phone.
      • Remove the two Pentalobe P2 screws at the bottom.
      • Remove the SIM card tray.
      Ask FixBot
    2. Huawei P10 Charging Board Replacement: step 2, image 1 of 3 Huawei P10 Charging Board Replacement: step 2, image 2 of 3 Huawei P10 Charging Board Replacement: step 2, image 3 of 3
      • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
      • Carefully pry the display with its parts out of the case.
      • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
      • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
      Ask FixBot
    3. Huawei P10 Charging Board Replacement: step 3, image 1 of 2 Huawei P10 Charging Board Replacement: step 3, image 2 of 2
      • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
      • Swing open the phone backwards.
      • Use a spudger to disconnect the power- and volume button flex cable.
      Ask FixBot
    1. Huawei P10 Charging Board Replacement, Battery disconnect: step 4, image 1 of 3 Huawei P10 Charging Board Replacement, Battery disconnect: step 4, image 2 of 3 Huawei P10 Charging Board Replacement, Battery disconnect: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the Phillips #00 screw.
      • Use tweezers to remove the metal plate.
      • Use a spudger to disconnect the battery flex cable.
      Ask FixBot
    1. Huawei P10 Charging Board Replacement, Charging Board: step 5, image 1 of 2 Huawei P10 Charging Board Replacement, Charging Board: step 5, image 2 of 2
      Buy
      • Remove the four Phillips #00 screws.
      • Use Tweezers to remove the metal plate.
      Ask FixBot
    2. Huawei P10 Charging Board Replacement: step 6, image 1 of 2 Huawei P10 Charging Board Replacement: step 6, image 2 of 2
      • Use a spudger to disconnect the main flex cable.
      • Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
      Ask FixBot
    3. Huawei P10 Charging Board Replacement: step 7, image 1 of 2 Huawei P10 Charging Board Replacement: step 7, image 2 of 2
      • Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
      Ask FixBot
    4. Huawei P10 Charging Board Replacement: step 8, image 1 of 2 Huawei P10 Charging Board Replacement: step 8, image 2 of 2
      • Do not damage any components sitting on the charging board while removing it.
      • Use a spudger to pry out the charging board.
      • Remove the charging board.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
16 other people completed this guide.
Dominik Schnabelrauch
266,083 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,713 Guides authored
4 Guide Comments
Just remember to take off a tape from the microphone on a new piece. I had to open mine twice
Michal Kornacki - Reply Share
If you have problems on connecting the cable to the charging port, before considering replacing the charging board, try removing the dust that may be occluding the port. Use tweezers to remove the dust and try if the cable connects. Do it carefully as your could damage the pins.
Gerard Encina Llamas - Reply Share
Second the above comment! - If you are having trouble fully inserting the USB cable, then try remove the dust with a pair of fine tweezers.
Andrew Norwood - Reply Share
I recently changed the battery of my P10 but the phone always died when the brandnew battery was still at 50%. It is no battery calibration issue - over the next ten days it got worse, died at 70%, now it frequently dies at 90%. The phone only starts with charging cable plugged in, then the battery charges from 90% to 100% in roughly one hour, but the "charged" battery only lasts about an hour or less, the phone dies when it reaches 90%. Looks to me like fake charging (or rather fake uncharging?). Is someone familiar with such an issue? Was the new battery defect from store? Or is the charger defect? The phone runs fine with power cable plugged in. Can it still be the charging board? Should I try the replacement shown in this article?
Xen - Reply Share
Past 24 Hours: 3
Past 7 Days: 38
Past 30 Days: 124
All Time: 8,691
