Up to 20% off select tools
Huawei P10 Battery Replacement
Views: 73K
View statistics:
Past 24 Hours:
8
Past 7 Days:
49
Past 30 Days:
281
All Time:
72,762
Comments: 28
12 comments on steps, 16 guide comments.
Go to guide comments
Completed: 83
83 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the battery in your Huawei P10 smartphone.
    1. Huawei P10 Battery Replacement, Back Cover: step 1, image 1 of 3 Huawei P10 Battery Replacement, Back Cover: step 1, image 2 of 3 Huawei P10 Battery Replacement, Back Cover: step 1, image 3 of 3
      • Switch off your phone.
      • Remove the two Pentalobe P2 screws at the bottom.
      • Remove the SIM card tray.
      Ask FixBot
    2. Huawei P10 Battery Replacement: step 2, image 1 of 3 Huawei P10 Battery Replacement: step 2, image 2 of 3 Huawei P10 Battery Replacement: step 2, image 3 of 3
      • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
      • Carefully pry the display with its parts out of the case.
      • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
      • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
      Ask FixBot
    3. Huawei P10 Battery Replacement: step 3, image 1 of 2 Huawei P10 Battery Replacement: step 3, image 2 of 2
      • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
      • Swing open the phone backwards.
      • Use a spudger to disconnect the power- and volume button flex cable.
      Ask FixBot
    1. Huawei P10 Battery Replacement, Battery: step 4, image 1 of 1
      • Remove the two Phillips #00 screws.
      Ask FixBot
    2. Huawei P10 Battery Replacement: step 5, image 1 of 2 Huawei P10 Battery Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove the two cable brackets.
      Ask FixBot
    3. Huawei P10 Battery Replacement: step 6, image 1 of 3 Huawei P10 Battery Replacement: step 6, image 2 of 3 Huawei P10 Battery Replacement: step 6, image 3 of 3
      • Use a spudger to disconnect the battery, the interconnect and the display flex cable.
      Ask FixBot
    4. Huawei P10 Battery Replacement: step 7, image 1 of 2 Huawei P10 Battery Replacement: step 7, image 2 of 2
      • The battery is glued in place with two adhesive strips. One with a pull tab and one without.
      • Peel out the adhesive strip which is placed beneath the battery by steadily pulling at the tab in a flat angle.
      • It is likely that the adhesive strip rips. In this case you can grab and twist it around a tweezers tip a couple of times and then continue.
      • Use an iOpener to loosen the remaining adhesive.
      Ask FixBot
    5. Huawei P10 Battery Replacement: step 8, image 1 of 2 Huawei P10 Battery Replacement: step 8, image 2 of 2
      Tesa 61395 Tape
      $8.95
      Buy
      • Take care to not bend or puncture the battery.
      • Insert an opening pick or spudger beneath the battery and carefully pry it out.
      • Remove the battery.
      • When reassembling your phone, replace old adhesive with stretch release adhesive strips, double-sided tape, or pre-cut adhesive strips.
      • Never reinstall a battery that has been bent or damaged during removal.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
83 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,200 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
16 Guide Comments
Thanks for posting this this give me new ideas.
Dave Dayanan - Reply Share
Facile comme bonjour. Les outils que j'avais reçu avec la batterie étaient de piètre qualité, j'ai donc utilisé des mini-spatules utilisées pour lisser les joints en silicone, c'est pile la consistance voulue pour décoller le dos et la batterie, ni trop ferme ni trop souple.
lepisosteus74 - Reply Share
Easy fix, thanks a lot.
Noé Barreau - Reply Share
Excellent guide, was done in 20 minutes, thankyou!
Mog Kupo - Reply Share
Eccellente guida peccato che una volta montata la nuova batteria in cellulare si sente che si accende la il display rimane buio, controllato connessioni ma sono tutte ok e display sempre spento, cosa può essere?
Adriano
Adriano Da Rold - Reply Share
Past 24 Hours: 8
Past 7 Days: 49
Past 30 Days: 281
All Time: 72,762
