Introduction
A portable device such as a tablet uses a touchscreen as its primary input. A touchscreen is any display that you interact with by simply touching it. The touchscreen of the tablet deteriorates over time. As a results, you experience touch lags, and sometimes your touchscreen just stops responding. In any case, you might need a screen replacement.In the following steps, we will walk you through how to remove and replace your touchscreen when you start having issues with it.
Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
Once the battery is removed, the motherboard is ready to be removed.
Remove the camera from the motherboard by disconnecting the clip next to it. You can use the precision tweezer here.
To remove the power port from the motherboard, unscrew the two 4mm screws with a T5 bit.
3 other people completed this guide.
