Huawei MediaPad M3 Motherboard Replacement
    1. Huawei MediaPad M3 Motherboard Replacement, Display Assembly: step 1, image 1 of 2 Huawei MediaPad M3 Motherboard Replacement, Display Assembly: step 1, image 2 of 2
      • Use a heat gun to heat the display. It may take up to 30 seconds.
      • Slide in the opening picks to the four corners of the tablet and peel off the display carefully.
      Ask FixBot
    2. Huawei MediaPad M3 Motherboard Replacement: step 2, image 1 of 2 Huawei MediaPad M3 Motherboard Replacement: step 2, image 2 of 2
      • Open the display carefully.
      • Use a Phillips #00 screwdriver to remove the two 3.0mm screws.
      Ask FixBot
    3. Huawei MediaPad M3 Motherboard Replacement: step 3, image 1 of 2 Huawei MediaPad M3 Motherboard Replacement: step 3, image 2 of 2
      • After removing the two screws, use your hand to take out the silver metal bracket.
      Ask FixBot
    4. Huawei MediaPad M3 Motherboard Replacement: step 4, image 1 of 3 Huawei MediaPad M3 Motherboard Replacement: step 4, image 2 of 3 Huawei MediaPad M3 Motherboard Replacement: step 4, image 3 of 3
      • Use the plastic opening tool to disconnect the two ribbon cable connectors.
      Ask FixBot
    5. Huawei MediaPad M3 Motherboard Replacement: step 5, image 1 of 2 Huawei MediaPad M3 Motherboard Replacement: step 5, image 2 of 2
      • Remove the display assembly from the device.
      Ask FixBot
    1. Huawei MediaPad M3 Motherboard Replacement, Front Camera: step 6, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the six 3.0mm screws.
      Ask FixBot
    2. Huawei MediaPad M3 Motherboard Replacement: step 7, image 1 of 1
      • Use your hand to remove the silver metal bracket.
      Ask FixBot
    3. Huawei MediaPad M3 Motherboard Replacement: step 8, image 1 of 2 Huawei MediaPad M3 Motherboard Replacement: step 8, image 2 of 2
      • Use your hand to remove the two black plastic covers.
      Ask FixBot
    4. Huawei MediaPad M3 Motherboard Replacement: step 9, image 1 of 3 Huawei MediaPad M3 Motherboard Replacement: step 9, image 2 of 3 Huawei MediaPad M3 Motherboard Replacement: step 9, image 3 of 3
      • Use a plastic opening tool to remove the front camera.
      Ask FixBot
    1. Huawei MediaPad M3 Motherboard Replacement, Rear Camera: step 10, image 1 of 3 Huawei MediaPad M3 Motherboard Replacement, Rear Camera: step 10, image 2 of 3 Huawei MediaPad M3 Motherboard Replacement, Rear Camera: step 10, image 3 of 3
      • Disconnect and remove the camera from the motherboard.
      Ask FixBot
    1. Huawei MediaPad M3 Motherboard Replacement, Motherboard: step 11, image 1 of 2 Huawei MediaPad M3 Motherboard Replacement, Motherboard: step 11, image 2 of 2
      • Use a Phillips #00 screwdriver to remove this 3mm screw.
      • Remove the small silver metal bracket.
      Ask FixBot
    2. Huawei MediaPad M3 Motherboard Replacement: step 12, image 1 of 2 Huawei MediaPad M3 Motherboard Replacement: step 12, image 2 of 2
      • First, remove the right ribbon cable from the board.
      • Next, remove the left ribbon cable from the board.
      Ask FixBot
    3. Huawei MediaPad M3 Motherboard Replacement: step 13, image 1 of 3 Huawei MediaPad M3 Motherboard Replacement: step 13, image 2 of 3 Huawei MediaPad M3 Motherboard Replacement: step 13, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the 3mm screw present on top of the silver metal bracket.
      • Remove the silver metal bracket from the board.
      • Remove the yellow ribbon cable using a plastic opening tool.
      Ask FixBot
    4. Huawei MediaPad M3 Motherboard Replacement: step 14, image 1 of 3 Huawei MediaPad M3 Motherboard Replacement: step 14, image 2 of 3 Huawei MediaPad M3 Motherboard Replacement: step 14, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the two 3mm screws.
      • Remove the black plastic cover from the board.
      Ask FixBot
    5. Huawei MediaPad M3 Motherboard Replacement: step 15, image 1 of 3 Huawei MediaPad M3 Motherboard Replacement: step 15, image 2 of 3 Huawei MediaPad M3 Motherboard Replacement: step 15, image 3 of 3
      • Carefully remove the motherboard from the device by using a plastic opening tool.
      Ask FixBot
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 28
Past 30 Days: 63
All Time: 2,574
