Huawei MediaPad M3 Display Assembly Replacement
    1. Huawei MediaPad M3 Display Assembly Replacement, Display Assembly: step 1, image 1 of 2 Huawei MediaPad M3 Display Assembly Replacement, Display Assembly: step 1, image 2 of 2
      • Use a heat gun to heat the display. It may take up to 30 seconds.
      • Slide in the opening picks to the four corners of the tablet and peel off the display carefully.
      Ask FixBot
    2. Huawei MediaPad M3 Display Assembly Replacement: step 2, image 1 of 2 Huawei MediaPad M3 Display Assembly Replacement: step 2, image 2 of 2
      • Open the display carefully.
      • Use a Phillips #00 screwdriver to remove the two 3.0mm screws.
      Ask FixBot
    3. Huawei MediaPad M3 Display Assembly Replacement: step 3, image 1 of 2 Huawei MediaPad M3 Display Assembly Replacement: step 3, image 2 of 2
      • After removing the two screws, use your hand to take out the silver metal bracket.
      Ask FixBot
    4. Huawei MediaPad M3 Display Assembly Replacement: step 4, image 1 of 3 Huawei MediaPad M3 Display Assembly Replacement: step 4, image 2 of 3 Huawei MediaPad M3 Display Assembly Replacement: step 4, image 3 of 3
      • Use the plastic opening tool to disconnect the two ribbon cable connectors.
      Ask FixBot
    5. Huawei MediaPad M3 Display Assembly Replacement: step 5, image 1 of 2 Huawei MediaPad M3 Display Assembly Replacement: step 5, image 2 of 2
      • Remove the display assembly from the device.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 34
All Time: 3,191
