Huawei Mate 9 Lite batterie replacement
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
82
All Time:
784
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide describes how to change the battery of the Huawei Mate 9 lite.
Parts
Tools
    1. Huawei Mate 9 Lite batterie replacement, Opening the smartphone: step 1, image 1 of 1
      • Heat the back of the device (e.g. with a hot-water bottle).
      • Then use a suction cup to lift the back a bit and insert a pick into the gap. Guide the pick once around the smartphone and loosen the glue, then remove the back cover.
      • Note the cable for the fingerprint sensor.
      • The back is made of a quite flexible plastic. Thus, you cannot easily destroy the back
      • There is a sticker with the serial number on the back. This has to be removed so that the suction cup holds well.
      Ask FixBot
    2. Huawei Mate 9 Lite batterie replacement, Disconnect cable from battery: step 2, image 1 of 1
      • Loosen the two screws that fix the cable on the right above the battery.
      • Disconnect the cable and the cables attached to the same connector from the mainboard.
      • Use a non-conductive object for this.
      Ask FixBot
    3. Huawei Mate 9 Lite batterie replacement: step 3, image 1 of 1
      • Now release the cable on the left side.
      • First, carefully bend the metal bracket that holds the cable on the right side a little to the side and then loosen the screw that holds the cable.
      • Then carefully pull the cable upwards.
      Ask FixBot
      • The battery is very firmly glued to the case.
      • Be careful when removing it!
      • I put the phone on a hot water bottle with the display facing down. This is not the best solution, but it works.
      Ask FixBot
      • To reassemble the smartphone, you first need to remove the adhesive residue that is present around the frame.
      • Then follow the last steps backwards.
      • Do not bend the metal bracket for the left cable back until you have already screwed the cable.
      Ask FixBot
Follow the instructions in reverse order to reassemble the device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Malte Kerl
186 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 82
All Time: 784
