Up to 20% off select tools
Huawei Mate 9 Display Replacement
Views: 22K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
155
All Time:
22,485
Comments: 11
4 comments on steps, 7 guide comments.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Moderate
Parts
  • Huawei Mate 9 Screen
    4.7
    View
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the display of your Huawei Mate 9 smartphone.
    1. Huawei Mate 9 Display Replacement, Back Cover: step 1, image 1 of 2 Huawei Mate 9 Display Replacement, Back Cover: step 1, image 2 of 2
      • First switch off your phone and remove the SIM card tray.
      Ask FixBot
    2. Huawei Mate 9 Display Replacement: step 2, image 1 of 2 Huawei Mate 9 Display Replacement: step 2, image 2 of 2
      • Remove both screws on the bottom with a Torx T2 screwdriver.
      • Use a plastic opening tool to get between the display and the case. Open the smartphone by carefully prying out the display with all the parts out of the case.
      • Don't open the phone all the way, yet. The fingerprint sensor cable is still connected to the back cover.
      Ask FixBot
    3. Huawei Mate 9 Display Replacement: step 3, image 1 of 2 Huawei Mate 9 Display Replacement: step 3, image 2 of 2
      • Swing open the phone to the right side.
      • Disconnect the fingerprint sensor cable with a spudger.
      Ask FixBot
    1. Huawei Mate 9 Display Replacement, Battery Disconnect: step 4, image 1 of 1
      • Carefully peel off the plastic sticker that holds both cables to the battery.
      Ask FixBot
    2. Huawei Mate 9 Display Replacement: step 5, image 1 of 1
      • Remove the water indicator sticker and the Phillips #00 screw beneath it, that holds the cable bracket in its place.
      Ask FixBot
    3. Huawei Mate 9 Display Replacement: step 6, image 1 of 1
      • Remove the cable bracket.
      Ask FixBot
    4. Huawei Mate 9 Display Replacement: step 7, image 1 of 3 Huawei Mate 9 Display Replacement: step 7, image 2 of 3 Huawei Mate 9 Display Replacement: step 7, image 3 of 3
      • Use a spudger to disconnect the interconnect, the battery and the display flex cable.
      Ask FixBot
    1. Huawei Mate 9 Display Replacement, Display: step 8, image 1 of 3 Huawei Mate 9 Display Replacement, Display: step 8, image 2 of 3 Huawei Mate 9 Display Replacement, Display: step 8, image 3 of 3
      • It's not required to remove the battery in order to remove the display of the Huawei Mate 9.
      • Disconnect the antenna cable and remove it carefully.
      • Remove the five Phillips #00 screws that hold the daughter board and loudspeaker in its place.
      Ask FixBot
    2. Huawei Mate 9 Display Replacement: step 9, image 1 of 2 Huawei Mate 9 Display Replacement: step 9, image 2 of 2
      • Remove the metal shield that covers the connection of the motherboard flex cable.
      • Use a spudger to unplug the motherboard flex cable and remove it.
      Ask FixBot
    3. Huawei Mate 9 Display Replacement: step 10, image 1 of 2 Huawei Mate 9 Display Replacement: step 10, image 2 of 2
      • Use a spudger to disconnect the loudspeaker and the charging port flex cable from the daughterboard.
      Ask FixBot
    4. Huawei Mate 9 Display Replacement: step 11, image 1 of 3 Huawei Mate 9 Display Replacement: step 11, image 2 of 3 Huawei Mate 9 Display Replacement: step 11, image 3 of 3
      • Use a spudger to carefully lever up the daughterboard and remove it. Don't break the small clamps that hold down the daughter board but press them a little bit to the side to make the removal easier.
      • Use a spudger to remove the loudspeaker and the charging port. There is some adhesive underneath and the unit might be a little bit sticky.
      • If you're having a hard time while removing the loudspeaker you can use an iOpener to loosen the adhesive and try it again.
      Ask FixBot
    5. Huawei Mate 9 Display Replacement: step 12, image 1 of 3 Huawei Mate 9 Display Replacement: step 12, image 2 of 3 Huawei Mate 9 Display Replacement: step 12, image 3 of 3
      • Use an iOpener to loosen the adhesive beneath the display. Focus on the top and bottom area of it.
      • After loosening the adhesive in the upper area of your phone, use an iFlex or opening pick and insert it carefully between the mid frame and your display.
      • Do not insert the tool more than approximately 1/16 of an inch on the sides.
      • Loosen the adhesive by sliding the along the mid frame.
      Ask FixBot
    6. Huawei Mate 9 Display Replacement: step 13, image 1 of 3 Huawei Mate 9 Display Replacement: step 13, image 2 of 3 Huawei Mate 9 Display Replacement: step 13, image 3 of 3
      • Then carefully slide around the whole mid frame.
      • If you're having a hard time while loosening the adhesive beneath the display you can reuse the iOpener and try it again.
      • After you loosened all the adhesive, start to slowly lift up the display from the bottom of your phone.
      Ask FixBot
    7. Huawei Mate 9 Display Replacement: step 14, image 1 of 2 Huawei Mate 9 Display Replacement: step 14, image 2 of 2
      • To completely remove the display you need to thread the flex cable through the gap in the mid frame.
      • When reassembling your phone apply new adhesive where it is necessary.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. When reassembling apply new adhesive where it is necessary.
14 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,208 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
7 Guide Comments
I have issue with the assembly process. Im adding 3m adhesive tape that I received with replacement screen, and everything looks fine. But after inserting phone into aluminium back the screen pop out int the middle of frame, delaminating and showing backlight of lcd. The adhesive just not hold it enough..
gingerboi66 - Reply Share
The iFlex isn’t listed in the tools.
Sean Hannold - Reply Share
Check, now it is listed. Thanks for the note.
Tobias Isakeit - Reply Share
it’s almost impossible to remove the battery without damaging it!
My advice to you is to buy the LCD screen with the battery included.
madani_salar - Reply Share
Hello,
do i have to remove the battery to change the display? That means is the removing of the battery absolutely necessary?
Greetings,
Mark
Mark D. - Reply Share
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 155
All Time: 22,485
