Huawei Mate 8 Loudspeaker Replacement
    1. Huawei Mate 8 Loudspeaker Replacement, Back Cover: step 1, image 1 of 2 Huawei Mate 8 Loudspeaker Replacement, Back Cover: step 1, image 2 of 2
      • Switch off your phone and remove the SIM card tray.
      Ask FixBot
    2. Huawei Mate 8 Loudspeaker Replacement: step 2, image 1 of 1
      • Remove the Torx T2 screws from the bottom of the phone
      Ask FixBot
    3. Huawei Mate 8 Loudspeaker Replacement: step 3, image 1 of 2 Huawei Mate 8 Loudspeaker Replacement: step 3, image 2 of 2
      • Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel.
      Ask FixBot
    4. Huawei Mate 8 Loudspeaker Replacement: step 4, image 1 of 3 Huawei Mate 8 Loudspeaker Replacement: step 4, image 2 of 3 Huawei Mate 8 Loudspeaker Replacement: step 4, image 3 of 3
      • Use an opening pick to fully separate the clips, releasing the phone.
      • Do not fully remove the rear case. The fingerprint sensor cable is still connected to the back cover.
      • Open the phone like a book from the SIM tray side.
      • Use a spudger, to disconnect the fingerprint sensor cable.
      Ask FixBot
    1. Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: step 5, image 1 of 3 Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: step 5, image 2 of 3 Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: step 5, image 3 of 3
      • Remove the liquid indicator sticker.
      • Remove the Phillips #00 screw that holds down the metal shield.
      • The metal shield is tightly held in place. If you try to remove it without holding it down on one side, it'll break easily.
      • Use a spudger to remove the metal shield.
      Ask FixBot
    2. Huawei Mate 8 Loudspeaker Replacement: step 6, image 1 of 3 Huawei Mate 8 Loudspeaker Replacement: step 6, image 2 of 3 Huawei Mate 8 Loudspeaker Replacement: step 6, image 3 of 3
      • Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables.
      Ask FixBot
    3. Huawei Mate 8 Loudspeaker Replacement: step 7, image 1 of 1
      • Remove the Phillips #00 screw that holds down the interconnect cable bracket.
      Ask FixBot
    4. Huawei Mate 8 Loudspeaker Replacement: step 8, image 1 of 2 Huawei Mate 8 Loudspeaker Replacement: step 8, image 2 of 2
      • Lift the coaxial connector off of its socket to allow access to the daughterboard interconnect cable bracket.
      • Remove the bracket.
      Ask FixBot
    5. Huawei Mate 8 Loudspeaker Replacement: step 9, image 1 of 1
      • Use a spudger to disconnect the interconnect cable.
      • Remove the interconnect cable.
      Ask FixBot
    1. Huawei Mate 8 Loudspeaker Replacement, Charging Board: step 10, image 1 of 3 Huawei Mate 8 Loudspeaker Replacement, Charging Board: step 10, image 2 of 3 Huawei Mate 8 Loudspeaker Replacement, Charging Board: step 10, image 3 of 3
      • Remove the two Phillips #00 screws.
      • Use the flat end a spudger to disconnect the loudspeaker flex connector.
      • Use the pointy end of a spudger to pry out the daughterboard.
      • Remove the daughterboard.
      Ask FixBot
    1. Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: step 11, image 1 of 3 Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: step 11, image 2 of 3 Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: step 11, image 3 of 3
      • Use the tip of a spudger on the left side of the loudspeaker to pry it out.
      • Remove the loudspeaker.
      Ask FixBot
4 other people completed this guide.
Theo Mat
13,019 Reputation
14 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 114
All Time: 1,615
