Up to 20% off select tools
Huawei Mate 8 Display Replacement
Views: 7.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
149
All Time:
7,549
Comments: 1
1 guide comment.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the defective display of your Huawei Mate 8.
    1. Huawei Mate 8 Display Replacement, Back Cover: step 1, image 1 of 2 Huawei Mate 8 Display Replacement, Back Cover: step 1, image 2 of 2
      • Switch off your phone and remove the SIM card tray.
      Ask FixBot
    2. Huawei Mate 8 Display Replacement: step 2, image 1 of 1
      • Remove the Torx T2 screws from the bottom of the phone
      Ask FixBot
    3. Huawei Mate 8 Display Replacement: step 3, image 1 of 2 Huawei Mate 8 Display Replacement: step 3, image 2 of 2
      • Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel.
      Ask FixBot
    4. Huawei Mate 8 Display Replacement: step 4, image 1 of 3 Huawei Mate 8 Display Replacement: step 4, image 2 of 3 Huawei Mate 8 Display Replacement: step 4, image 3 of 3
      • Use an opening pick to fully separate the clips, releasing the phone.
      • Do not fully remove the rear case. The fingerprint sensor cable is still connected to the back cover.
      • Open the phone like a book from the SIM tray side.
      • Use a spudger, to disconnect the fingerprint sensor cable.
      Ask FixBot
    1. Huawei Mate 8 Display Replacement, Daughterboard interconnect cable: step 5, image 1 of 3 Huawei Mate 8 Display Replacement, Daughterboard interconnect cable: step 5, image 2 of 3 Huawei Mate 8 Display Replacement, Daughterboard interconnect cable: step 5, image 3 of 3
      • Remove the liquid indicator sticker.
      • Remove the Phillips #00 screw that holds down the metal shield.
      • The metal shield is tightly held in place. If you try to remove it without holding it down on one side, it'll break easily.
      • Use a spudger to remove the metal shield.
      Ask FixBot
    2. Huawei Mate 8 Display Replacement: step 6, image 1 of 3 Huawei Mate 8 Display Replacement: step 6, image 2 of 3 Huawei Mate 8 Display Replacement: step 6, image 3 of 3
      • Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables.
      Ask FixBot
    3. Huawei Mate 8 Display Replacement: step 7, image 1 of 1
      • Remove the Phillips #00 screw that holds down the interconnect cable bracket.
      Ask FixBot
    4. Huawei Mate 8 Display Replacement: step 8, image 1 of 2 Huawei Mate 8 Display Replacement: step 8, image 2 of 2
      • Lift the coaxial connector off of its socket to allow access to the daughterboard interconnect cable bracket.
      • Remove the bracket.
      Ask FixBot
    5. Huawei Mate 8 Display Replacement: step 9, image 1 of 1
      • Use a spudger to disconnect the interconnect cable.
      • Remove the interconnect cable.
      Ask FixBot
    1. Huawei Mate 8 Display Replacement, Battery: step 10, image 1 of 1
      • The battery is glued in place with two adhesive strips. One with a pull tab and one without.
      • Get a good grip on the pull tab near the power button and peel out the adhesive strip by steadily pulling at the tab in a flat angle.
      • If the adhesive strip rips, grab and twist it around the tweezer tips a couple of times and then continue.
      Ask FixBot
    2. Huawei Mate 8 Display Replacement: step 11, image 1 of 3 Huawei Mate 8 Display Replacement: step 11, image 2 of 3 Huawei Mate 8 Display Replacement: step 11, image 3 of 3
      • Do not bend or puncture the battery, damage to the cell can cause battery fires.
      • Heat an iOpener and place it on the phone for about a minute to loosen the remaining adhesive.
      • Carefully insert the flat end of a spudger to separate any remaining adhesive at the top of the battery.
      Ask FixBot
    3. Huawei Mate 8 Display Replacement: step 12, image 1 of 2 Huawei Mate 8 Display Replacement: step 12, image 2 of 2
      • Lift the top end of the battery to pull the battery off of the remaining adhesive strip.
      • When reassembling your phone, apply stretch release adhesive strips, double sided adhesive tape, or pre-cut adhesive to secure the new battery.
      • Never reinstall a battery that has been bent or damaged during removal.
      Ask FixBot
    1. Huawei Mate 8 Display Replacement, Display: step 13, image 1 of 1
      • Remove the four Phillips #00 screws holding the daughterboard and loudspeaker to the phone.
      Ask FixBot
    2. Huawei Mate 8 Display Replacement: step 14, image 1 of 2 Huawei Mate 8 Display Replacement: step 14, image 2 of 2
      • Use the flat end of a spudger to disconnect the loudspeaker connector cable.
      • Use the tip of a spudger to lift the daughterboard from the phone.
      Ask FixBot
    3. Huawei Mate 8 Display Replacement: step 15, image 1 of 2 Huawei Mate 8 Display Replacement: step 15, image 2 of 2
      Tool used on this step:
      Buy
      • Insert the flat end of a spudger under the loudspeaker at the gap on the left side.
      • Work the spudger under the loudspeaker to seperate it from the adhesive and remove the loudspeaker.
      • Use tweezers to take the vibration unit out of its housing.
      Ask FixBot
    4. Huawei Mate 8 Display Replacement: step 16, image 1 of 1
      • Remove the eight Phillips #00 screws securing the motherboard to the phone.
      Ask FixBot
    5. Huawei Mate 8 Display Replacement: step 17, image 1 of 2 Huawei Mate 8 Display Replacement: step 17, image 2 of 2
      • Remove the bracket from the rear camera flex cable.
      • Use tweezers to disconnect the antenna cable.
      Ask FixBot
    6. Huawei Mate 8 Display Replacement: step 18, image 1 of 3 Huawei Mate 8 Display Replacement: step 18, image 2 of 3 Huawei Mate 8 Display Replacement: step 18, image 3 of 3
      • Use the flat end of a spudger to disconnect the volume and power flex cable on the bottom left side of the mainboard.
      • Work the flat end of a spudger under the top right side of the mainboard to pry it out.
      • Remove the mainboard.
      Ask FixBot
    7. Huawei Mate 8 Display Replacement: step 19, image 1 of 2 Huawei Mate 8 Display Replacement: step 19, image 2 of 2
      • Remove the antenna interconnect cable.
      • Remove the power and volume switch assembly.
      Ask FixBot
    8. Huawei Mate 8 Display Replacement: step 20, image 1 of 3 Huawei Mate 8 Display Replacement: step 20, image 2 of 3 Huawei Mate 8 Display Replacement: step 20, image 3 of 3
      • Use tweezers to remove the earpiece speaker.
      • Remove the red rubber gasket.
      • Remove the ambient light and proximity sensor.
      Ask FixBot
9 other people completed this guide.
Author
with
Dominik Schnabelrauch
268,208 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
1 Guide Comment
Tidy. Really tidy like.
Marc Vestabule - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 149
All Time: 7,549
