Huawei Mate 10 lite battery replacement
    1. Huawei Mate 10 lite battery replacement, Remove SIM card: step 1, image 1 of 1
      • Remove the SIM card by using a paperclip or a special tool and inserting it into the hole next to the SIM card tray until it pops out.
      Ask FixBot
    2. Huawei Mate 10 lite battery replacement, Open the case: step 2, image 1 of 2 Huawei Mate 10 lite battery replacement, Open the case: step 2, image 2 of 2
      • Remove the Torx T2 screws on the bottom of the case(next to the USB port)
      • Place the opening tool at the bottom and press down on the housing.
      • go around the side to open the phone
      • place the device screen down and take the backcover off to the left side
      Ask FixBot
    3. Huawei Mate 10 lite battery replacement, Remove the cables: step 3, image 1 of 1
      • Red: Phillips #00 screws
      • Blue: Remove the cable clamps with the Spudger
      • Remove the cables connecting to the backside and remove the cables that run over the battery
      Ask FixBot
    4. Huawei Mate 10 lite battery replacement, Remove the battery: step 4, image 1 of 2 Huawei Mate 10 lite battery replacement, Remove the battery: step 4, image 2 of 2
      • Insert the plastic card into the side and push them under the battery
      • the glue under the battery can be removed with highgrade IPA or a special glue remover. Otherwise you can pry the battery out with the spudger, the plastic cards and the opening picks
      Ask FixBot
Follow the guide in the opposite direction and use the replacement battery.
8 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Maximilian Deisz
894 Reputation
3 Guides authored
1 Guide Comment
Achtung: Ich habe irrtümlich das Display "zerlegt", weil der aufgeblähte Akku hier einen Spalt gemacht hat, in den ich leider das Tool angesetzt habe... :/
Mario Taferl - Reply Share
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 92
All Time: 5,458
