Introduction
Accessing the motherboard of the Huawei Mate 10 Pro is often an important step in solving hardware issues. Whether it is to access other parts of the device or to install a new motherboard, this guide will show the steps needed to safely remove it.
Insert a SIM opening tool in the hole on the left side and push it in.
Remove the SIM card tray.
Switch off your phone.
Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
Tool used on this step:Halberd Spudger$2.99
Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
Tool used on this step:Tweezers$4.99
Unscrew screws on black cover and remove using tweezers to leverage.
