Huawei Mate 10 Pro Camera Assembly Replacement
    1. Huawei Mate 10 Pro Camera Assembly Replacement, SIM Card Tray: step 1, image 1 of 2 Huawei Mate 10 Pro Camera Assembly Replacement, SIM Card Tray: step 1, image 2 of 2
      • Insert a SIM opening tool in the hole on the left side and push it in.
      • Remove the SIM card tray.
      Ask FixBot
    1. Huawei Mate 10 Pro Camera Assembly Replacement, Back Cover: step 2, image 1 of 1
      • Switch off your phone.
      • Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
      Ask FixBot
    2. Huawei Mate 10 Pro Camera Assembly Replacement: step 3, image 1 of 3 Huawei Mate 10 Pro Camera Assembly Replacement: step 3, image 2 of 3 Huawei Mate 10 Pro Camera Assembly Replacement: step 3, image 3 of 3
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
      • Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
      • Use opening picks to avoid the adhesive from sticking to the back cover again while cutting the adhesive on all sides.
      Ask FixBot
    3. Huawei Mate 10 Pro Camera Assembly Replacement: step 4, image 1 of 2 Huawei Mate 10 Pro Camera Assembly Replacement: step 4, image 2 of 2
      • Don't remove the back cover all the way, yet. The fingerprint sensor cable is still connected to motherboard.
      • Flip the back cover over to the side.
      • Remove the Phillips #00 screw which holds down the metal shield, sitting on top of the connection of the fingerprint sensor cable.
      Ask FixBot
    4. Huawei Mate 10 Pro Camera Assembly Replacement: step 5, image 1 of 2 Huawei Mate 10 Pro Camera Assembly Replacement: step 5, image 2 of 2
      Buy
      • Use a pair tweezers to remove the metal shield covering the connector of the fingerprint sensor.
      • Disconnect the fingerprint sensor cable with a spudger.
      • When reassembling your phone apply new adhesive where it is necessary.
      Ask FixBot
    1. Huawei Mate 10 Pro Camera Assembly Replacement, Motherboard: step 6, image 1 of 2 Huawei Mate 10 Pro Camera Assembly Replacement, Motherboard: step 6, image 2 of 2
      Buy
      • Unscrew screws on black cover and remove using tweezers to leverage.
      Ask FixBot
    2. Huawei Mate 10 Pro Camera Assembly Replacement: step 7, image 1 of 2 Huawei Mate 10 Pro Camera Assembly Replacement: step 7, image 2 of 2
      • Pop off gold covers.
      Ask FixBot
    3. Huawei Mate 10 Pro Camera Assembly Replacement: step 8, image 1 of 3 Huawei Mate 10 Pro Camera Assembly Replacement: step 8, image 2 of 3 Huawei Mate 10 Pro Camera Assembly Replacement: step 8, image 3 of 3
      • Disconnect wires attached to motherboard assembly.
      Ask FixBot
    4. Huawei Mate 10 Pro Camera Assembly Replacement: step 9, image 1 of 2 Huawei Mate 10 Pro Camera Assembly Replacement: step 9, image 2 of 2
      • Wedge tweezers under motherboard and leverage assembly to pop assembly out.
      Ask FixBot
    5. Huawei Mate 10 Pro Camera Assembly Replacement: step 10, image 1 of 1
      • Separate camera assembly by popping it out, if only the motherboard is needed.
      Ask FixBot
    1. Huawei Mate 10 Pro Camera Assembly Replacement, Camera Assembly: step 11, image 1 of 3 Huawei Mate 10 Pro Camera Assembly Replacement, Camera Assembly: step 11, image 2 of 3 Huawei Mate 10 Pro Camera Assembly Replacement, Camera Assembly: step 11, image 3 of 3
      • On the backside of the motherboard assembly, detach the camera assembly from the motherboard.
      Ask FixBot
2 other people completed this guide.
Annabelle Harding
433 Reputation
3 Guides authored
IUPUI, Team 3-5, Harley Spring 2022 Member of IUPUI, Team 3-5, Harley Spring 2022
IUPUI-HARLEY-S22S3G5
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 43
All Time: 1,091
