Huawei Mate 10 Pro Back Cover Replacement
    1. Huawei Mate 10 Pro Back Cover Replacement, SIM Card Tray: step 1, image 1 of 2 Huawei Mate 10 Pro Back Cover Replacement, SIM Card Tray: step 1, image 2 of 2
      • Insert a SIM opening tool in the hole on the left side and push it in.
      • Remove the SIM card tray.
      Ask FixBot
    1. Huawei Mate 10 Pro Back Cover Replacement, Back Cover: step 2, image 1 of 1
      • Switch off your phone.
      • Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
      Ask FixBot
    2. Huawei Mate 10 Pro Back Cover Replacement: step 3, image 1 of 3 Huawei Mate 10 Pro Back Cover Replacement: step 3, image 2 of 3 Huawei Mate 10 Pro Back Cover Replacement: step 3, image 3 of 3
      Tool used on this step:
      Halberd Spudger
      $2.99
      Buy
      • Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
      • Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
      • Use opening picks to avoid the adhesive from sticking to the back cover again while cutting the adhesive on all sides.
      Ask FixBot
    3. Huawei Mate 10 Pro Back Cover Replacement: step 4, image 1 of 2 Huawei Mate 10 Pro Back Cover Replacement: step 4, image 2 of 2
      • Don't remove the back cover all the way, yet. The fingerprint sensor cable is still connected to motherboard.
      • Flip the back cover over to the side.
      • Remove the Phillips #00 screw which holds down the metal shield, sitting on top of the connection of the fingerprint sensor cable.
      Ask FixBot
    4. Huawei Mate 10 Pro Back Cover Replacement: step 5, image 1 of 2 Huawei Mate 10 Pro Back Cover Replacement: step 5, image 2 of 2
      Buy
      • Use a pair tweezers to remove the metal shield covering the connector of the fingerprint sensor.
      • Disconnect the fingerprint sensor cable with a spudger.
      • When reassembling your phone apply new adhesive where it is necessary.
      Ask FixBot
14 other people completed this guide.
Dominik Schnabelrauch
263,537 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
85,577 Guides authored
3 Guide Comments
Where can I buy the back part of the phone. Email me at brownpridebandit@gmail.com
Luis Liberato - Reply Share
Thanks for good work you do
amoudi Guide - Reply Share
Thanks for the job
When reassembling the phone what kind of adhesive can I use ?
email me at : aptel.one@proton.me
Thanks for your reply
Jds75 - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 57
All Time: 18,379
