Huawei M750 Charging Port Replacement
    1. Huawei M750 Charging Port Replacement, Battery: step 1, image 1 of 1
      • Depress the top of the battery cover, and pull downwards towards the base of the phone.
      Ask FixBot
    2. Huawei M750 Charging Port Replacement: step 2, image 1 of 1
      • Remove the battery by levering the battery out, using the cut just below the camera.
      Ask FixBot
    1. Huawei M750 Charging Port Replacement, Back Panel: step 3, image 1 of 1
      • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
      • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
      Ask FixBot
    2. Huawei M750 Charging Port Replacement: step 4, image 1 of 2 Huawei M750 Charging Port Replacement: step 4, image 2 of 2
      • Using the T5 Torx screwdriver, remove the six 6mm screws.
      Ask FixBot
    3. Huawei M750 Charging Port Replacement: step 5, image 1 of 2 Huawei M750 Charging Port Replacement: step 5, image 2 of 2
      • Using the opening tool, pry the back panel from the front panel.
      • Work your way around the phone until the panels separate evenly.
      • This step may require a substantial amount of leverage.
      Ask FixBot
    1. Huawei M750 Charging Port Replacement, Charging Port: step 6, image 1 of 2 Huawei M750 Charging Port Replacement, Charging Port: step 6, image 2 of 2
      • Using the opening tool, start prying out the motherboard from the front panel along the border.
      • When the motherboard seems separated from the front panel, pull it outwards.
      Ask FixBot
    2. Huawei M750 Charging Port Replacement: step 7, image 1 of 2 Huawei M750 Charging Port Replacement: step 7, image 2 of 2
      • The charging port is soldered to the motherboard, use this guide to do the replacement.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 59
All Time: 674
