Up to 20% off select tools
Huawei M750 Camera Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
75
All Time:
765
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will show how to replace the camera on a Huawei M750 smartphone.
    1. Huawei M750 Camera Replacement, Battery: step 1, image 1 of 1
      • Depress the top of the battery cover, and pull downwards towards the base of the phone.
      Ask FixBot
    2. Huawei M750 Camera Replacement: step 2, image 1 of 1
      • Remove the battery by levering the battery out, using the cut just below the camera.
      Ask FixBot
    1. Huawei M750 Camera Replacement, Back Panel: step 3, image 1 of 1
      • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
      • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
      Ask FixBot
    2. Huawei M750 Camera Replacement: step 4, image 1 of 2 Huawei M750 Camera Replacement: step 4, image 2 of 2
      • Using the T5 Torx screwdriver, remove the six 6mm screws.
      Ask FixBot
    3. Huawei M750 Camera Replacement: step 5, image 1 of 2 Huawei M750 Camera Replacement: step 5, image 2 of 2
      • Using the opening tool, pry the back panel from the front panel.
      • Work your way around the phone until the panels separate evenly.
      • This step may require a substantial amount of leverage.
      Ask FixBot
    1. Huawei M750 Camera Replacement, Camera: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • The camera's connection to the motherboard is shown here.
      • Using the tweezers, disconnect the port, shown here in the picture.
      Ask FixBot
    2. Huawei M750 Camera Replacement: step 7, image 1 of 1
      • Using the tweezers, carefully remove the lens and lens casing.
      • It should be held in by a simple tight fit. The front panel is what keeps the lens secured.
      • Do not touch the camera lens, or the digital camera component, if possible. This will prevent scratching, or damage.
      Ask FixBot
Author
with
Stuart Smith
156 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 75
All Time: 765
