Up to 20% off select tools
Huawei M750 Back Panel Replacement
View statistics:
Past 24 Hours:
7
Past 7 Days:
18
Past 30 Days:
69
All Time:
794
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide show the process of back panel replacement on the Huawei M750.
    1. Huawei M750 Back Panel Replacement, Battery: step 1, image 1 of 1
      • Depress the top of the battery cover, and pull downwards towards the base of the phone.
      Ask FixBot
    2. Huawei M750 Back Panel Replacement: step 2, image 1 of 1
      • Remove the battery by levering the battery out, using the cut just below the camera.
      Ask FixBot
    1. Huawei M750 Back Panel Replacement, Back Panel: step 3, image 1 of 1
      • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
      • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
      Ask FixBot
    2. Huawei M750 Back Panel Replacement: step 4, image 1 of 2 Huawei M750 Back Panel Replacement: step 4, image 2 of 2
      • Using the T5 Torx screwdriver, remove the six 6mm screws.
      Ask FixBot
    3. Huawei M750 Back Panel Replacement: step 5, image 1 of 2 Huawei M750 Back Panel Replacement: step 5, image 2 of 2
      • Using the opening tool, pry the back panel from the front panel.
      • Work your way around the phone until the panels separate evenly.
      • This step may require a substantial amount of leverage.
      Ask FixBot
Author
with
Kshitiz Thapa
389 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 18
Past 30 Days: 69
All Time: 794
