Huawei Honor 9 Battery Replacement
    1. Huawei Honor 9 Battery Replacement, Remove the Rear Glass: step 1, image 1 of 1
      • Switch off your phone.
      • Heat an iOpener and apply it to the back of the phone for around two minutes. This will help soften the adhesive securing the rear glass.
      • You might need to reheat and reapply the iOpener several times during the rear glass removal.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
      Ask FixBot
    2. Huawei Honor 9 Battery Replacement: step 2, image 1 of 2 Huawei Honor 9 Battery Replacement: step 2, image 2 of 2
      • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
      • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
      • Lift the rear glass with the suction cup to create a gap between the glass and the frame.
      • Insert an opening pick into the gap.
      • Don't attempt to insert a pick between the back glass and the frame before creating a gap. The glass is covered with foil from the inside, and by not creating a gap, you risk inserting the pick between the glass and the foil instead, which would permanently damage the foil and ruin the solid color of the back panel.
      • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
      Ask FixBot
    3. Huawei Honor 9 Battery Replacement: step 3, image 1 of 3 Huawei Honor 9 Battery Replacement: step 3, image 2 of 3 Huawei Honor 9 Battery Replacement: step 3, image 3 of 3
      • Slide the opening pick to the bottom right corner.
      • Insert a second opening pick and slide it to the bottom left corner.
      • Leave the opening picks in place to prevent the adhesive from resealing.
      Ask FixBot
    4. Huawei Honor 9 Battery Replacement: step 4, image 1 of 3 Huawei Honor 9 Battery Replacement: step 4, image 2 of 3 Huawei Honor 9 Battery Replacement: step 4, image 3 of 3
      • Insert a third opening pick at the bottom left corner.
      • Start to slide the tip of the opening pick from the bottom left corner along the side of the Huawei Honor 9 to cut the adhesive.
      • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
      Ask FixBot
    5. Huawei Honor 9 Battery Replacement: step 5, image 1 of 2 Huawei Honor 9 Battery Replacement: step 5, image 2 of 2
      • If the adhesive gets hard to cut it is likely too cold. Use your iOpener to reheat it.
      • Insert a fourth opening pick under the top left corner of the rear glass.
      • Slide the opening pick along the top edge of the phone to cut the adhesive.
      • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. Huawei Honor 9 Battery Replacement: step 6, image 1 of 2 Huawei Honor 9 Battery Replacement: step 6, image 2 of 2
      • Insert a fifth opening pick at the top right corner of the phone.
      • Slide the opening pick along the right side to cut the remaining adhesive.
      Ask FixBot
    7. Huawei Honor 9 Battery Replacement: step 7, image 1 of 2 Huawei Honor 9 Battery Replacement: step 7, image 2 of 2
      Tool used on this step:
      Tesa 61395 Tape
      $8.95
      Buy
      • Carefully lift the rear glass and remove it.
      • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape.
      • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
      Ask FixBot
    1. Huawei Honor 9 Battery Replacement, Remove the Motherboard Shield: step 8, image 1 of 1
      • Remove the three Phillips #00 screws (3.45 mm length).
      • Remove the five Phillips #00 screws (2.9 mm length).
      Ask FixBot
    2. Huawei Honor 9 Battery Replacement: step 9, image 1 of 2 Huawei Honor 9 Battery Replacement: step 9, image 2 of 2
      • Carefully peel up the black thermal foil and remove it completely.
      • This foil is very thin and brittle and may rip easily.
      • Remove the Phillips #00 screw that is located underneath the thermal foil at the bottom center of the motherboard.
      Ask FixBot
    3. Huawei Honor 9 Battery Replacement: step 10, image 1 of 2 Huawei Honor 9 Battery Replacement: step 10, image 2 of 2
      • Slide an opening pick under the right side of the motherboard shield.
      • Twist the opening pick sideways to release the clips that hold the shield in place.
      • Repeat the previous process and work your way around the motherboard shield until it pops out.
      Ask FixBot
    4. Huawei Honor 9 Battery Replacement: step 11, image 1 of 1
      • Remove the motherboard shield.
      Ask FixBot
    1. Huawei Honor 9 Battery Replacement, Disconnect the Battery: step 12, image 1 of 2 Huawei Honor 9 Battery Replacement, Disconnect the Battery: step 12, image 2 of 2
      • Use a spudger to pry up and disconnect the battery flex cable.
      Ask FixBot
    1. Huawei Honor 9 Battery Replacement, Remove the Battery: step 13, image 1 of 3 Huawei Honor 9 Battery Replacement, Remove the Battery: step 13, image 2 of 3 Huawei Honor 9 Battery Replacement, Remove the Battery: step 13, image 3 of 3
      • Apply an iOpener to the center of the display, to loosen the adhesive beneath the battery.
      • The adhesive beneath the battery is very strong. You might need to repeat this process during the removal procedure several times. If heat does not work you can apply isopropyl alcohol (90+%) to the corners of the battery and let it penetrate the adhesive for several minutes before continuing.
      • The flex cables under the battery are laid out as seen in the image. Try to avoid prying in the marked areas to prevent damaging the cables.
      • Display flex cable
      • Interconnect flex cable
      Ask FixBot
    2. Huawei Honor 9 Battery Replacement: step 14, image 1 of 3 Huawei Honor 9 Battery Replacement: step 14, image 2 of 3 Huawei Honor 9 Battery Replacement: step 14, image 3 of 3
      • Try your best not to deform the battery during the following removal process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
      • Insert the flat end of a spudger at the top right corner of the battery where the flex cable is located and start to pry the battery up.
      • Work your way down the right side of the battery and loosen the adhesive with the spudger.
      Ask FixBot
    3. Huawei Honor 9 Battery Replacement: step 15, image 1 of 3 Huawei Honor 9 Battery Replacement: step 15, image 2 of 3 Huawei Honor 9 Battery Replacement: step 15, image 3 of 3
      • Insert the flat end of a spudger at the top left corner of the battery and pry the battery up.
      Ask FixBot
    4. Huawei Honor 9 Battery Replacement: step 16, image 1 of 3 Huawei Honor 9 Battery Replacement: step 16, image 2 of 3 Huawei Honor 9 Battery Replacement: step 16, image 3 of 3
      Plastic Cards
      $2.99
      Buy
      • The display and interconnect flex cables are running underneath the battery. Don't damage them while cutting the remaining adhesive.
      • Insert an opening pick or plastic card between the frame and the battery.
      • Cut any remaining adhesive underneath the battery.
      • Pry up the battery until you can get a good grip.
      Ask FixBot
    5. Huawei Honor 9 Battery Replacement: step 17, image 1 of 1
      Tesa 61395 Tape
      $8.95
      Buy
      • Remove the battery.
      • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
      • Remove any remaining adhesive from the phone and clean the glued areas with isopropyl alcohol and a lint-free cloth before installing the new battery.
      • If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
      • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
      Ask FixBot
12 other people completed this guide.
Dominik Schnabelrauch
266,119 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,737 Guides authored
3 Guide Comments
J’ai réussi ce remplacement de batterie
Il ne faut pas hésiter à bien chauffer la partie basse pour réussir à y rentrer un médiator, et éviter de tordre l'appareil lors de l’insertion !
La batterie est vraiment très bien collée et il faut forcer plus que ce que je m’attendais pour réussir à l’extirper ! Ne pas hésiter à bien la chauffer également après l’avoir déconnectée !
Merci pour le tutoriel ainsi que sa traduction !
Maxime Dewasmes - Reply Share
Merci beaucoup pour ce tutoriel !
Apres 4 ans d’utilisation, c’est reparti j’espère pour au moins 3 ans de plus avec ce téléphone.
Pour le iOpener, j’ai du réchauffer à la casserolle, cela fonctionne mieux en laissant un peu plus de 3 minutes dans l’eau bouillante. J’ai du répéter l’opération environ 3 fois pour venir à bout de cette fichue colle.
A l’étape 7 “fixez votre nouvelle vitre avec de l'adhésif prédécoupé ou du ruban adhésif double-face.” La nouvelle vitre est en fait l’ancienne mais qu’on colle à la toute fin de la réparation.
Je ne sais pas si il fallait remettre la feuille thermique noire mais je' l’ai fait grâce aux bouts de ruban adhésif.
Encore merci iFixit pour ce précieux travail :) !
Roger - Reply Share
Merci de m'avoir aider
Medjahed belakehal - Reply Share
Past 24 Hours: 13
Past 7 Days: 61
Past 30 Days: 208
All Time: 24,133
